Frankz 2 Posted July 29, 2018 Posted July 29, 2018 (edited) TV Model: KS7000 Emby Server: Version 3.6.0.2 beta Audio Track mix-upAudio Tracks 2 & 3 are wrongly displayed/selected in the Emby Tizen app. Example mediainfo of audiotracks: Audio #1 ID : 2 Format : TrueHD Format profile : TrueHD+Atmos / TrueHD Codec ID : A_TRUEHD Duration : 2 h 2 min Bit rate mode : Variable Bit rate : 4 603 kb/s Maximum bit rate : 7 806 kb/s Channel(s) : Object Based / 8 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE Sampling rate : / 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Delay relative to video : 32 ms Stream size : 3.93 GiB (6%) Title : Dolby Atmos/ TrueHD Audio / English / 7.1-Atmos / 48 kHz / 5243 kbps / 24-bit Language : English Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 2 h 2 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 31 ms Stream size : 560 MiB (1%) Language : English Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 2 h 2 min Bit rate mode : Constant Bit rate : 224 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 196 MiB (0%) Title : Audio Commentary Language : English Service kind : Complete Main Default : No Forced : No This is what the audio drop-down menu shows:1. TrueHD2. Dolby Digital 5.13. Dolby Digital Stereo What happens when you select these?1. TrueHD > Track1: TrueHD is played2. Dolby Audio 5.1 > Track3: 2.0 Commentary Track is played(displaying "statistics for nerds" will show 640kbps)3. Stereo > Track2: Dolby audio 5.1 is played(displaying "statistics for nerds" will show 224kbps)Subtitle Selection When there is a forced subtitle present it will autoselect that forced subtitle, and ignore your setting of preferring a subtitle from a certain language. So upon selecting a movie, it will have the Forced subtitle selected, even when your preferred subtitle is available. When this happens you will have to select the subtitle you want manually. Edited July 29, 2018 by Frankz
Luke 42241 Posted July 29, 2018 Posted July 29, 2018 This is resolved for the next app update. Thanks. 2
