servingjoy51 2 Posted July 29, 2018 Posted July 29, 2018 My server is using too much CPU when playing live tv (using plugin), i have two PC's and i tried to encode the live tv using ffmpeg (x264, libmp3lame / x264 aac, with all possible bitrate combinations) and route the out to emby. Emby app stat says transcoding because mediabitrate exceed limit. I even tried the same ffmpeg transcoding settings that emby use (from process view in linux). This also result in transcoding. Can anyone post a ffmpeg setting that will result in an output stream that will directplay in emby app (mainly roku), i will not be worried if it is a single device, for each device playing emby starts a new process. so ultimately my server crashes. My incoming format x264 aac
Luke 42237 Posted July 29, 2018 Posted July 29, 2018 Hi there, can we look at an example? Please attach the information requested in how to report a media playback issue. thanks !
