ddurdle 75 Posted July 28, 2018 Posted July 28, 2018 What is the best way to add an additional language for an existing library. When you checkbox the additional language in subtitles, it applies it to new files that are added. Is there an elegant way to "back load" the srt fetch for existing files?
Luke 42212 Posted July 28, 2018 Posted July 28, 2018 If you are referring to subtitle downloading then just run the subtitle download scheduled task.
ddurdle 75 Posted July 31, 2018 Author Posted July 31, 2018 I added NOR to the language selector in the Subtitle section of the dashboard, and in the ~40,000 STRM files I have, only 38 were with NOR srt files after 3 days. I've tried running the job manually and it is causing quota issues on STRM files as whenever the subtitle job runs since adding NOR, I'm hitting quota exceeded on the destination end, like something is trying to probe all the STRM files. But I'm not seeing anything to suggest that by looking at the embyserver.txt log.
Luke 42212 Posted July 31, 2018 Posted July 31, 2018 It could be the perfect match option, if that is enabled. Try turning that off.
