and135531 0 Posted July 28, 2018 Posted July 28, 2018 (edited) Hello,i recently got my first NAS (DS218play), unfortunately it is not really working with emby. I can't watch transcoding videos on my android tv without pausing every 2 seconds. The CPU is going up to 99% utilization. I also tried different Hardware acceleration, but it doesn't gets better. I heard there are problems with the ARMv8 cpu. Is there a way to fix this, or should I switch to another NAS like the DS218+? I really hope someone can help me. And sorry for my bad English ffmpeg-transcode-b3f89ac0-4636-4187-9722-e3706e93f1ef.txt Edited July 28, 2018 by and135531
Luke 42241 Posted July 28, 2018 Posted July 28, 2018 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
and135531 0 Posted July 28, 2018 Author Posted July 28, 2018 I added the server log. Missed the "attach this file" button Do you need anything else?
Luke 42241 Posted July 28, 2018 Posted July 28, 2018 Are you playing in the browser, and if so, which browser?
and135531 0 Posted July 28, 2018 Author Posted July 28, 2018 No, I am playing with the emby app on my sony bravia with android tv. At the browser I can use direct playing and this works without problems. I used the emby server on windows before and this works with my android tv, too.
PaoloPinkel 6 Posted July 28, 2018 Posted July 28, 2018 (edited) Edit: it was crap here... Edited July 30, 2018 by PaoloPinkel
solabc16 379 Posted July 30, 2018 Posted July 30, 2018 Hello @@and135531 There aren't any issues with the ARMv8 CPU per se, for all practical purposes it simply doesn't have the performance to perform software transcoding. These CPUs do not have any support for h/w transcoding. However, this NAS should be capable of running Emby Server with reasonable performance and able to support a number of direct play clients. That's the key, you have to be targeting direct play only, this isn't the right h/w if transcoding in your setup is unavoidable. Best - James
Luke 42241 Posted July 31, 2018 Posted July 31, 2018 We're happy to review log files when you get back. Thanks !
