viktor80 0 Posted July 28, 2018 Posted July 28, 2018 Hi, I used VAAPI hardware accelerated transcoding without any issue on emby server 3.2.x. I upgraded to 3.5.1 and there is no VAAPI, only cpu transcoding. (cpu cores are on 100% and quality is bad on the client) I checked the log and I don't see -vaapi_device /dev/dri/renderD128 parameter. Is there any change in FFMpeg 4 parameters or should I do some additional configuration? Is it possible somehow to modify the ffmpeg parameters which the emby server generate? I use Debian sid. Thanks your help in advance. /opt/emby-server/bin/ffmpeg -ss 00:17:54.000 -i file:"/pool/some_movie.avi" -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -prese t veryfast -crf 23 -maxrate 3648738 -bufsize 7297476 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=n one -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af "volume= 2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -segment_time_delta -1074 -individual_head er_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 358 -segment_list "/var/lib/emby/transcoding-temp/7b387cfdadadc4cd0cd3407b11377b5f.m3u 8" -y "/var/lib/emby/transcoding-temp/7b387cfdadadc4cd0cd3407b11377b5f%d.ts" ffmpeg version 4.0.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-g++ --arch=x86_64 --prefix=/home/emby builder/Buildbot-master/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl -- enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enab le-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lz -lvorbis -logg -lnettle -lhogweed -l gmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common- samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssap i_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-d gm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-suppor t-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util - lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsoc ket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg- samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-libsmbclient --enable -cuda --enable-cuvid --enable-nvenc --enable-vaapi <?xml version="1.0"?> <EncodingOptions xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <EncodingThreadCount>-1</EncodingThreadCount> <TranscodingTempPath /> <DownMixAudioBoost>2</DownMixAudioBoost> <EnableThrottling>true</EnableThrottling> <ThrottleDelaySeconds>180</ThrottleDelaySeconds> <HardwareAccelerationType>vaapi</HardwareAccelerationType> <VaapiDevice>/dev/dri/renderD128</VaapiDevice> <H264Crf>23</H264Crf> <H264Preset /> <EnableHardwareEncoding>true</EnableHardwareEncoding> <EnableSubtitleExtraction>true</EnableSubtitleExtraction> <HardwareDecodingCodecs /> </EncodingOptions> /# vainfo error: can't connect to X server! libva info: VA-API version 1.2.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_2 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.2 (libva 2.1.0) vainfo: Driver version: Intel i965 driver for Intel(R) Broxton - 2.2.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD # ls -al /dev/dri total 0 drwxr-xr-x 3 root root 100 júl 28 06:28 . drwxr-xr-x 18 root root 3060 júl 28 06:28 .. drwxr-xr-x 2 root root 80 júl 28 06:28 by-path crw-rw---- 1 root video 226, 0 júl 28 06:28 card0 crw-rw---- 1 root video 226, 128 júl 28 06:28 renderD128 emby user is member of video group video:x:44:emby
Luke 42246 Posted July 28, 2018 Posted July 28, 2018 Hi there, please attach the complete ffmpeg log. thanks.
viktor80 0 Posted July 28, 2018 Author Posted July 28, 2018 try againffmpeg-transcode-f9d85d62-6e6e-40ec-9195-7367e879ed99.txt
Luke 42246 Posted July 28, 2018 Posted July 28, 2018 Hi, the input file here is mpeg4, which is not supported by vaapi. If you try an input file where the video is h264, then it should work.
viktor80 0 Posted July 28, 2018 Author Posted July 28, 2018 (edited) Thanks, it's working. I didn't notice that difference. Is it possible to use vaapi in emby if the source is mpeg4, but the output is h264? As I know ffmpeg supports sw decode, hw encode transcoding. Edited July 28, 2018 by viktor80
Luke 42246 Posted July 28, 2018 Posted July 28, 2018 In our experience this causes an error and that's why we've disabled it.
