daouid 0 Posted July 27, 2018 Posted July 27, 2018 Hello, Thanks for you great work :-)I am testing Emby on an old Android phone, with Android 4.1.The installation is ok, the connection is ok, i can see movies and music but i can't read it.The phone say : Playback Error No compatible streams are currently availableI use unsecure connection to be sure with the default port.The server work with Android device most recent and in my navigator (on my pc, and on Firefox in the old android 4.1)Log don't tell about error.Do you have an idea ?What is the minimal Android version ?Thanks in advance
Luke 42244 Posted July 27, 2018 Posted July 27, 2018 Hi, minimal Android version is 4.2. for anything lower I would suggest using the mobile web app. Please let us know if this helps. Thanks.
