JensWillems 0 Posted July 26, 2018 Posted July 26, 2018 Hi, I just started up Emby since i'm no longer happy with Plex. I created a server on my PC, and want to stream my movies/series on my LG TV. However when i try to connect to my mediaserver, i get a connection failure error. I've already tried everything which is stated in following guidelines: https://github.com/MediaBrowser/Wiki/wiki/Connectivity I even ported my modem, and the port is not blocked? So i really don't get why the server will not work on my LG TV? Can anyone help me out? Thanks!
Luke 42212 Posted July 26, 2018 Posted July 26, 2018 Hi there, have you been successful in connecting from another device to your server, such as a smartphone for example?
JensWillems 0 Posted July 26, 2018 Author Posted July 26, 2018 (edited) Hi there, have you been successful in connecting from another device to your server, such as a smartphone for example? Hi Luke, Yes, i can connect via my iphone with no problem at all. Edited July 26, 2018 by JensWillems
JensWillems 0 Posted July 26, 2018 Author Posted July 26, 2018 How are you trying to connect on the LG? Via the Emby application on my smart TV. It detects my server's name when i put in the pin code which is prompted on the screen, but when i try to connect it, i receive a connection failure error.
Luke 42212 Posted July 28, 2018 Posted July 28, 2018 @@JensWillems, what happens if instead of the pin code method, you try adding the server manually into the LG app?
JensWillems 0 Posted July 29, 2018 Author Posted July 29, 2018 @@JensWillems, what happens if instead of the pin code method, you try adding the server manually into the LG app? Then it can't connect to the server. It says it doesn't find it.
Luke 42212 Posted July 30, 2018 Posted July 30, 2018 @@JensWillems What exactly did you enter into the server host name field?
