siteripper2 0 Posted July 26, 2018 Posted July 26, 2018 (edited) Hello, I am working on a plugin for emby. This Plugin scrapes info from a site and I have a question: which format emby accept the metadata and poster and where to upload? Because emby doesn’t provide any api to upload. A sample data file to upload on bulk would be great. With best regards, Frank Edited July 26, 2018 by siteripper2
ebr 16344 Posted July 26, 2018 Posted July 26, 2018 Hi. If you plan to publish this plug-in, please see our Development Policy. It sounds like you should be writing a metadata provider plug-in. You might want to look at one of the existing ones to see how that is done. Thanks.
siteripper2 0 Posted July 26, 2018 Author Posted July 26, 2018 (edited) I am not planning to publish this plugin as it is scraping info from my own site. Where/How can I look into the exisiting ones? Edited July 26, 2018 by siteripper2
ebr 16344 Posted July 26, 2018 Posted July 26, 2018 Here is an example that provides data and images. https://github.com/MediaBrowser/Emby/tree/master/MediaBrowser.Providers/Omdb
