gsites 14 Posted July 25, 2018 Posted July 25, 2018 HelloI need old versions of emby for android 4.4.2Where can I download?I use on android TV Beelink X2Thank you
ebr 16337 Posted July 25, 2018 Posted July 25, 2018 Hi. You would need to use the mobile app. "Android TV" didn't exist until 5.0.
gsites 14 Posted July 27, 2018 Author Posted July 27, 2018 Mobile or TV? Mobile where to download the previous versions? Thank you
Luke 42244 Posted July 27, 2018 Posted July 27, 2018 The current version in the play store is compatible with 4.2+.
gsites 14 Posted July 27, 2018 Author Posted July 27, 2018 The current version in the play store is compatible with 4.2+. Yes, I downloaded the version that is in the playstore, but it does not open correctly, I did it 5 times and it did not work. So I wanted to know about old versions, previous versions to download, before this new version the mobile worked very well on android tv. There is no place to download older versions? Thank you
gsites 14 Posted July 27, 2018 Author Posted July 27, 2018 What happens when you try to open it? I can get into the server, but it does not load, just keep trying. I have smartphones that work perfect, which has android 7.1. But, this android tv is android version 4.4.2 and does not work the emby by the application. If I use chrome to watch it works, but only in browser, not application. I wanted to use the emby application because it is easier to navigate through the files and choose which one to watch. Thank you
Solution Luke 42244 Posted July 27, 2018 Solution Posted July 27, 2018 For an old device like that you might be better off with the web app. In fact, if this is for a TV, you might even prefer: http://tv.emby.media That interface is designed for tv usage. 1
