after update to 3.5.1.0 many problems / all users away / port change not possible
SilentStorm
I have in /etc/emby-server.conf add EMBY_USER=root and change http port on /emby-server/config/system.xml  / not running
I have copied all users from old directory into the new directory / not running
I did the same as last time, why does not that work
please help me I can not get any further
Edited by SilentStorm
angusleung
As I know you could not change user by using old method since 3.3
If you are using systemd
You may try
sudo systemctl enable emby-server@[YOUR_USER] --now
For data directory you may edit it in "/etc/emby-server.conf"
e.g.
EMBY_DATA=/var/lib/emby-server
Edited by angusleung
  • Like 1
