MindBullet 93 Posted July 25, 2018 Posted July 25, 2018 (edited) Hello everybody, I'm a long-term Plex enthusiast, coming to Emby for its vast customization options (compared to Plex) and I'm loving every aspect of Emby. However, I just can't seem to get Hardware acceleration working, as it won't "stay" turned on. I have a Windows 10 machine with an Intel i5-7400, 16GBs of RAM and an Nvidia Geforce GTX 1050. As I would have thought the only to options for me to accelerate the hardware would therefore be: Nvidia NVENC or QuickSync. I tried both methods (would prefer quicksync tho, since Nvidia has limitations to 2 concurrents) and both are not persistant. When I turn either on, I come back 15 minutes later to the transcode section et voilá - they're turned off! I tried it with multiple settings for the codecs, having them all switched on or only one or two switched on - makes no difference at all. So my question is: What can I do to get the hardware acceleration? As I know from Plex my setup definately is capable in doing so, as almost every transcode on Plex was hardware accelerated. And I'd love to have the same for Emby. Could anybody point me to a direction? Or maybe there's somebody out there with the same problem? Is my rudimental assumption of either QuickSync or NVENC wrong?If anybody could help me solving this I'd be grateful af EDIT: To avoid missunderstandings: I mean the hardware decoding options like x264, x265 etc. are not persistant Edited July 25, 2018 by GodOnEmby
Luke 42216 Posted July 25, 2018 Posted July 25, 2018 Hi, welcome. Are you sure you actually saved it? We don't have anything that would actually change the setting on you. In other words, there's no part of the server that will change your configured value.
MindBullet 93 Posted July 25, 2018 Author Posted July 25, 2018 @@Luke you're pretty fast with answering, I like that Yes! I saved it of course. The weird thing is the time. If I come back immediately after changing the settings, it's still there. When I come back 10+ minutes later - it's not. Is there anything I could try from my windows system settings? I tried playing around with the NVIDIA settings. Maybe the problem has vanished already?And by the way: Does it make a difference if I alter these settings eith from app.emby.media or localhost:8096? As I would've thought it doesn't matter from where I change it, amirite? Kind regards and thanks for your helpful and quick replies
Luke 42216 Posted July 25, 2018 Posted July 25, 2018 And by the way: Does it make a difference if I alter these settings eith from app.emby.media or localhost:8096? As I would've thought it doesn't matter from where I change it, amirite? For these two, no, it wouldn't matter.
MindBullet 93 Posted July 25, 2018 Author Posted July 25, 2018 (edited) Ok that's what I thought. But you're implying that it does matter for other settings? Which ones would that be?Anyways I have no freaggin' idea how that's possible, but the settings are now persistant. I really have no idea how that's possible, as it was behaving like I said above since I had the server installed 3 days ago, but it seems to work now. Maybe I've ticked the right thing in the NVIDIA settings? I'm too unknowing about these things, but no matter how it's working. @@Luke one more question: I'm about to update the server to the current beta and I've read in the changelog that hwacc is now using dxva2. Do I still have to select QuickSynd for my computer?Last question. Have a great day/night ahead wherever you are EDIT: Nope. Again it's gone... EDIT 2: It appears that they're gone as soon as I have anybody playing something from outside of my network Edited July 25, 2018 by GodOnEmby
Luke 42216 Posted July 25, 2018 Posted July 25, 2018 No it doesn't matter for any setting. Are you sure someone isn't just changing it? Do I still have to select QuickSync for my computer? Yes you do, but just FYI all of this is in stable now.
MindBullet 93 Posted July 25, 2018 Author Posted July 25, 2018 (edited) As I'm the only one having administrator privileges I guess nobody could be able to change it. I have no idea. Just to clearify the point: Hardware acceleration is constantly switched on and set to QuickSync, so is hardware encoding. But I have no luck with switching on hardware decoding for specific codecs. It just keeps getting unticked over and over again. Or maybe it's just a displaying bug? I don't have a single clue Edited July 25, 2018 by GodOnEmby
Luke 42216 Posted July 25, 2018 Posted July 25, 2018 Have you tried to play content that will utilize the features?
MindBullet 93 Posted July 25, 2018 Author Posted July 25, 2018 Have you tried to play content that will utilize the features? Yeah, definately. I only have content in x264, x265 and mpeg and I belive 4 movies in VC1. Nothing else. As I said as soon as somebody plays any video file from another network the settings for hardware decoding are/seem to be turned off again
Guest asrequested Posted July 25, 2018 Posted July 25, 2018 So what happens if you set it, and play something that is being transcoded? Does it stay enabled?
MindBullet 93 Posted July 25, 2018 Author Posted July 25, 2018 (edited) So what happens if you set it, and play something that is being transcoded? Does it stay enabled? Sorry for the delay guys. I'm busy with setting up Emby and figuring things out Well it doesn't matter whether it's a transcode or not - it doesn't stay enabled (thanks for that word ) either way. Direct Streams included. As I said earlier I was a long-term Plex user, decided to go to Emby, installed the Emby server, decided to go back to Plex and afterwards I came back to Emby again, for the last time Might that have something to do with it?! And to be more precise: If I, myself, play anything in my local network it stays enabled, yes Edited July 25, 2018 by GodOnEmby
MindBullet 93 Posted July 25, 2018 Author Posted July 25, 2018 I think I give up on this one. As I was playing around with settings it turns out, that hardware acceleration is always enabled, just not the de-/encodings. I also read a recommendation on another thread that Intel Core PCs should leave the de-/ and endcodings untouched, so I think that's just fine for now Anyways thank you so much for supporting me as a bit of a noob. Have a good night or day ahead Love
Guest asrequested Posted July 25, 2018 Posted July 25, 2018 So encoding is working but not decoding? There some adjustments being made on that. It would be helpful if you could post transcode logs with encoding and decoding, enabled. And probably with decoding, disabled.
Luke 42216 Posted July 26, 2018 Posted July 26, 2018 Thanks that's good feedback. I'm going to redesign that selection UI in the near future.
MindBullet 93 Posted July 26, 2018 Author Posted July 26, 2018 So encoding is working but not decoding? There some adjustments being made on that. It would be helpful if you could post transcode logs with encoding and decoding, enabled. And probably with decoding, disabled. Yeah I will, sure. But atm I have some huge traffic on my server and if I enable these settings all the streams are going to crash. Thanks that's good feedback. I'm going to redesign that selection UI in the near future. I have no idea what's wrong, even tho I think a redesign might be helpful for many users Maybe with some further explanations. Sorry for this entire thread. A very good thing about Emby is the high level of customization, which was the reason for me to leave Plex. But it might also be a high-level of error sources. So it can be both for noobs like me: Curse and blessing at once Have a great day ahead
snake98 10 Posted September 27, 2018 Posted September 27, 2018 (edited) I'm having the same issues, intel quick sync I just check the last log C:\Users\Snake98\AppData\Roaming\Emby-Server\system\ffmpeg.exe -re -i file:"\\SERVER\embytv\9-1-1\9-1-1 2018_09_23_17_00_00 - Under Pressure.ts" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames "expr:gte(t,n_forced*5)" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,min(1920\,1080*dar))/2)*2:trunc(min(max(iw/dar\,ih)\,min(1920/dar\,1080))/2)*2" -preset veryslow -look_ahead 0 -b:v 9632734 -maxrate 9632734 -bufsize 19265468 -r 30 -profile:v high -level 4.1 -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -ar 44100 -y "C:\Users\Snake98\AppData\Roaming\Emby-Server\programdata\sync\d8eadf9b5cbf44eea15ddac87b0a578a\567a23647d67413b92ec4f4121cdc563\a9400f07-e62b-4b81-8da3-ea60725aa704.mp4" I thought I was going crazy, but this has been happening for months. Just thought I was doing something, or if hardware decode failed, it would disable it-self. I knew it fail on mpeg2 decode with Intel quicksync, known problem, but they have it fixed in the new nightly build, which I'm using. Using Windows version, and configuring with Firefox. . Edited September 27, 2018 by snake98
Luke 42216 Posted September 27, 2018 Posted September 27, 2018 It's resolved for Emby Server 3.6. Thanks.
KarlDag 25 Posted November 28, 2018 Posted November 28, 2018 (edited) I've just realised this is happening for me too. As soon as I switch to another section of the server dashboard and come back it's off again. Is 3.6 coming soon? Is the beta pretty stable? @@Luke Edited November 28, 2018 by KarlDag
Hitsville 37 Posted November 29, 2018 Posted November 29, 2018 I've just realised this is happening for me too. As soon as I switch to another section of the server dashboard and come back it's off again. Is 3.6 coming soon? Is the beta pretty stable? @@Luke As for the beta it's extremely stable. I run it on both my local server and remote dedi without issue. Sent from my SM-G935F using Tapatalk 1
KarlDag 25 Posted November 29, 2018 Posted November 29, 2018 As for the beta it's extremely stable. I run it on both my local server and remote dedi without issue. Sent from my SM-G935F using Tapatalk Great, thanks.
