jorgitoxp 1 Posted November 11, 2020 Posted November 11, 2020 1 hour ago, PuffyToesToo said: Hi @PuffyToesToo this works no need to change label. Appreciate it so much. If you have the one for Animation Station with just the label "Animation" it would be great. Look at my full setup below. 1
PuffyToesToo 348 Posted November 11, 2020 Author Posted November 11, 2020 Did you mean this one? Or do you want it to just say Biography?
jorgitoxp 1 Posted November 11, 2020 Posted November 11, 2020 3 hours ago, PuffyToesToo said: @PuffyToesToo this is perfect...Now i have all my genres covered. Thank you so much, love your work. Sent you a small donation early today to support your work.
spaceman07 8 Posted February 17, 2021 Posted February 17, 2021 (edited) hello.. is it possible to get some with MUSICAL,FAMILY, SHORT, TV MOVIE,WAR, BOLLYWOOD, ANIME TV, ANIME MOVIES? thanks Edited February 17, 2021 by spaceman07 1
PuffyToesToo 348 Posted February 17, 2021 Author Posted February 17, 2021 I believe if you look at the posts, you should find all of your requests save for Bollywood, which I can do for you.
KoteZA 6 Posted February 19, 2021 Posted February 19, 2021 (edited) @PuffyToesToo Firstly, thanks for all these great images ! Could I ask for the following: (in order of preference) WAR (can be same as War Films without the Films part) FAMILY (can be same as Family Films without Films part) CHILDREN TALK SHOW SOAPIES Or if you can send me the font used, i can try use some of the blank images, but yours do look so good and contextual Edited February 19, 2021 by KoteZA 1
PuffyToesToo 348 Posted February 20, 2021 Author Posted February 20, 2021 On 2/19/2021 at 8:27 AM, KoteZA said: @PuffyToesToo Firstly, thanks for all these great images ! Could I ask for the following: (in order of preference) WAR (can be same as War Films without the Films part) FAMILY (can be same as Family Films without Films part) CHILDREN TALK SHOW SOAPIES Or if you can send me the font used, i can try use some of the blank images, but yours do look so good and contextual Sure, I'll post when they're ready. 1
PuffyToesToo 348 Posted February 24, 2021 Author Posted February 24, 2021 On 2/17/2021 at 6:36 AM, spaceman07 said: hello.. is it possible to get some with MUSICAL,FAMILY, SHORT, TV MOVIE,WAR, BOLLYWOOD, ANIME TV, ANIME MOVIES? thanks Were you able to locate all of the other images?
KoteZA 6 Posted February 24, 2021 Posted February 24, 2021 @PuffyToesToo Thanks, you absolute legend 1
xd003 7 Posted April 14, 2021 Posted April 14, 2021 (edited) The images are really great , no doubt. Although its getting bit difficult to explore them here . The zip file needs to be updated time to time and even if someone needs a particular image , they gotta download the whole zip file. I suggest you can simply just upload all your images in google drive and share the public url , then you can simply update anything there , it will be lot more convenient for everyone . Lastly thanks for the great work Edited April 14, 2021 by xd003 1
Guest Posted April 14, 2021 Posted April 14, 2021 (edited) DeviantArt.com is a good place to submit your work and host it as well... I have been a member for around 16 years... 14 as the username I have now... Almost abandoned as I never had time r money to do what I wanted to do.. You can separate these into Theme based Submissions.. and link to them.. I used to be HEAVILY involved back in the day.. major modder when it comes to Windows.. Harder to pull off now in Windows 10.. Skins, Mods, Configs... you name it... The site has changed quite a bit over the years but you should find a category to list these in. It's a good place to share your creativity and works with other people from the same type of community. Think you might like it.. Edited April 14, 2021 by Guest
