chris7197 0 Posted July 24, 2018 Posted July 24, 2018 Hi all, is there any way of getting a Hauppauge TV tuner working on Emby for Synology? It doesn't seem to be detecting the TV tuner
arrbee99 1836 Posted July 25, 2018 Posted July 25, 2018 No idea about Hauppauge and Synology except to say, as far as I know, you need to get / check tuner is working first. For Windows you need to set up using WinTV8 or 8.5 and see that it tunes and plays and then hopefully it'll be detected in Emby. If you use NextPVR or something you need to set it up and see that its working in the NextPVR app then install the NextPVR plugin in Emby and update the guide after that in Emby. Again, this is for Windows, am hoping its basically the same for Synology.
Luke 42241 Posted July 25, 2018 Posted July 25, 2018 Hi, we don't support it natively on Synology, but it can be used with additional software. If you install TvHeadEnd, then you can import Hauppauge channels into Emby via TVHeadEnd's m3u output feature. Please let us know if this helps. Thanks !
