lanos 4 Posted April 2, 2014 Posted April 2, 2014 I start kinect it ask to pick user to control then just repeatedly says "I'm having a problem loading designation grammar I will rectify the problem immediately" it says that about 20 or so times and opens a notepad document every time so end up with 20 or so notepads all titled token and saying Arguments = WScript.Arguments.Item(0) Set wmp = CreateObject("WMPlayer.OCX") wmp.settings.autoStart = True wmp.settings.volume = 50 wmp.URL = Arguments while wmp.Playstate <> 1 WSH.Sleep 10 Wend wscript.Quit then after its done with that mdkinect just stops all together
chef 3811 Posted April 3, 2014 Posted April 3, 2014 (edited) Hi! Please follow this link and join the discussion. HTTPS://mediabrowser.tv/community/index.php?/topic/5449-help-mb-kinect-crashing-immediately-on-windows-81/?fromsearch=1 There is a pre release test of the newest version. Unfortunately, the version you have is fairly old. I want to update the main link if this newest installer goes well. @@lanos Edited April 3, 2014 by chef
