Luke 42244 Posted August 12, 2018 Posted August 12, 2018 Why are you forwarding the ssl port (8920) to the http port?
samuelqwe 317 Posted August 12, 2018 Posted August 12, 2018 (edited) Like Luke says, you want to map 8920 to 8920 (https port), and 8096 to 8096 (http port), unless you've changed these in the Emby settings. Also, why are you mapping these ports on different local IP addresses? You want to make sure that both port forwards are mapped to the correct local IP, which is the one for your server. Finally, if you can, it may also be helpful to give your server a static local IP, so that it doesn't change when you try to access the server remotely. Edited August 12, 2018 by samuelqwe
