tamim2007 5 Posted July 20, 2018 Posted July 20, 2018 After the last update 1.0.43 the playback is buffering too much and jumping a few seconds by itself. I've tested many videos all have the same issue. I reinstalled the app and restarted the server also nothing changes. I use a local network with LAN. I have no issue with DLNA also it's way much faster. Samsung model number: KS8000 Samsung firmware version: 1220 Emby client version #: 3.5.0.0 Thanks guys
Luke 42241 Posted July 20, 2018 Posted July 20, 2018 Strange, haven't seen this. Have you tried restarting the TV and/or pulling the TV network connection and putting it back in?
tamim2007 5 Posted July 20, 2018 Author Posted July 20, 2018 Thank Luke for your reply. Yes I did. I'll reinstall the server and see. Other devices like Android app don't have this issue.
tamim2007 5 Posted July 20, 2018 Author Posted July 20, 2018 (edited) Unfortunately, the issue is soo annoying especially with a big video size over 8GB. I tried everything possible even using a portable server and a clean library. Thanks Edited July 20, 2018 by tamim2007
valkhyr 6 Posted July 20, 2018 Posted July 20, 2018 (edited) I have the problem with my samsung KS7000 and emby server 3.5.0.0, after downgrading the emby server to 3.4.1.0 everything is working fine. In this topic shocker has the same problem https://emby.media/community/index.php?/topic/60368-34123-samsung-app-official-is-skipping/?hl=%26quot%3B3+mbps%26quot%3B&do=findComment&comment=596649 Edited July 20, 2018 by valkhyr 1
Luke 42241 Posted July 20, 2018 Posted July 20, 2018 To be honest I think it is a coincidence that you changed versions and it made a difference.
valkhyr 6 Posted July 20, 2018 Posted July 20, 2018 I have tried this several times, my problem started with server 3.4.1.13-beta or 14. After downgrading to version 3.4.1.0 the problem was gone. When I upgrade my emby servers (linux and windows) to version 3.5.0.0 the jumping problem returns. 1
shadetree 6 Posted July 20, 2018 Posted July 20, 2018 I can reproduce the OP's issue with Samsung KS8000 using emby Version 3.5.0.0. Prior to the update, all local video and Live TV were direct play with never an issue. Now testing any playback will soon stop and jerk , blackout, and or crash trying to transcode. I gave up trying to fix it and reverted back to Version 3.4.1.0, still working like a charm. Oh, disabled auto update. 1
tamim2007 5 Posted July 20, 2018 Author Posted July 20, 2018 I have the problem with my samsung KS7000 and emby server 3.5.0.0, after downgrading the emby server to 3.4.1.0 everything is working fine. In this topic shocker has the same problem https://emby.media/community/index.php?/topic/60368-34123-samsung-app-official-is-skipping/?hl=%26quot%3B3+mbps%26quot%3B&do=findComment&comment=596649 You're totally right when I downgraded the server to 3.4.1.0 the issue has gone and it works great and smooth. Yah I have to disable the auto-update until the amazing guys solve the issue. 1
Solution Luke 42241 Posted July 21, 2018 Solution Posted July 21, 2018 If you could try beta server 3.6.0.2 and let me know if that makes a difference, that would be helpful. thanks. 2
tamim2007 5 Posted July 21, 2018 Author Posted July 21, 2018 awesome Luke. yaaah It's fixed and works so smooth on 3.6.0.2. Thanks and really appreciate all the hard work you've done. 1
valkhyr 6 Posted July 21, 2018 Posted July 21, 2018 Beta server 3.6.0.2 works without problems Thanks Luke for the quick solution.
shadetree 6 Posted July 21, 2018 Posted July 21, 2018 The algorithm to examine the mediasource is fixed with Beta server 3.6.0.2, using Samsung TV clients. My family is happy now...lol. Thank You!
Luke 42241 Posted July 21, 2018 Posted July 21, 2018 What operating system are you guys running the server on?
Frankz 2 Posted July 21, 2018 Posted July 21, 2018 Windows 10, Build 17134 I was also experiencing skipping on 3.5.0, I have yet been able to try out 3.6.0.2 Beta, but will report back when I can later tonight.
tamim2007 5 Posted July 21, 2018 Author Posted July 21, 2018 What operating system are you guys running the server on? Windows 10
