bradleyccook 0 Posted July 20, 2018 Posted July 20, 2018 hi there, i was a long time Plex user, with a massive library.... The library is kinda jumbled as far as naming conventions go, not to the spec that EMby is wanting it [(title) ((year))].[ext]. in saying that my library is jumbled, there is still a form of order as all my movies follow 1 of 3 naming conventions, as do my series etc.. so now the question/request: the ability to create a filename mask for the importing of a library where these "different" to the "norm" naming conventions are used, so that time can be taken to input the mask, then the library can be scanned once, and all files metadata found. and in reverse, the ability, to find a listing of files/directories that have been found and catalogued vs those that havent so a user can know where to start with a renaming effort..... thanks... Brad ps... loving Emby thus far
Luke 42246 Posted July 20, 2018 Posted July 20, 2018 Hi , thanks for the feedback. Can you give examples of the conventions that you use? Perhaps we can support them. Thanks.
