Leanback interface for non-certified devices
Hi there.
I'm really enjoying the Emby experience on my TV using DLNA. It works a lot better than Plex. I can't use Android app properly because my Android box is not certified. Usually, non-certified boxes tend to be slower and most of them don't use the latest versions of Android. Certified is also more expensive.
The thing is: I can't use Leanback interface on my MX9 Pro Android Box. The same also happens with a lot of non-certified devices.
Plex, for example, lets you switch the interface to Leanback in any device if you use their app. VLC Player for Android also has the same option.
I wish Emby could do the same OR maybe add support for using remote (D-pad) while using their non-Android TV app. For now, I can only access settings with my remote control.
That's the only option missing that's avoiding me to go Premium.
Edited by gabiluz
Hi.  What version of Android is this box running?
