Latchmor 584 Posted September 3, 2014 Posted September 3, 2014 Mmm, in the UK on 23rd Oct: http://t.co/MGofXSKz9g Yes or no ?...... I'm a Prime user so get it for £49
Latchmor 584 Posted September 3, 2014 Posted September 3, 2014 Can't say no for £49 really can you? Not really. The Lovefilm/Amazon Prime app on my telly is a little sluggish so I'd use this a lot more I think. Then MB of course
Deihmos 170 Posted September 4, 2014 Posted September 4, 2014 (edited) Get a FLIRC, works perfectly to give one IR on a Fire TV....The roku has more content and works with IR. They all do the same thing so it isn't serious. I already have an IR receiver for the htpc. Edited September 3, 2014 by Deihmos
Scot 27 Posted September 4, 2014 Posted September 4, 2014 Fire TV works with XBMC, vastly more powerful than a ROKU and a much much nicer interface....with a FLIRC it leaves the ROKU for dust....
Deihmos 170 Posted September 4, 2014 Posted September 4, 2014 Fire TV works with XBMC, vastly more powerful than a ROKU and a much much nicer interface....with a FLIRC it leaves the ROKU for dust.... Prefer to use my HTPC and not interested in XBMC. Thanks.
Spaceboy 2573 Posted September 4, 2014 Posted September 4, 2014 Yeah I won't be using it with xbmc Sent from my iPhone using Tapatalk
Latchmor 584 Posted September 5, 2014 Posted September 5, 2014 Yeah I pre-ordered mine. £50 price ends Monday in case you didn't notice.
mini__me 28 Posted September 5, 2014 Posted September 5, 2014 Guess I'll be ordering this weekend then
w84no1 27 Posted September 6, 2014 Posted September 6, 2014 Yeah I won't be using it with xbmc Sent from my iPhone using Tapatalk XBMC is the only reason I bought one 1
mini__me 28 Posted September 6, 2014 Posted September 6, 2014 Not sure whether to buy one or wait for Android TV. Argh problem is there is always something around the corner, just need to decide and stick with it I guess, at £50 it's almost throw away after 6 months money!
Deihmos 170 Posted September 6, 2014 Posted September 6, 2014 Anyone buying this to use XBMC better read up because it isn't a matter of installing it from a store. You need to root the device and will have to do it over every time there is an update.
bluemonkey07 590 Posted September 6, 2014 Posted September 6, 2014 Anyone buying this to use XBMC better read up because it isn't a matter of installing it from a store. You need to root the device and will have to do it over every time there is an update.Is SPMC not available from the Amazon store as a free download for fireTV? It is a android version of XBMC ... No root required I believe
mini__me 28 Posted September 6, 2014 Posted September 6, 2014 I'm hoping to be able to use the MB3 app on it and not XBMC/Kodi at all
Deihmos 170 Posted September 6, 2014 Posted September 6, 2014 Is SPMC not available from the Amazon store as a free download for fireTV? It is a android version of XBMC ... No root required I believeNo. The fire TV does not use an android store and amazon has its own OS based on Android.
bluemonkey07 590 Posted September 6, 2014 Posted September 6, 2014 (edited) No. The fire TV does not use an android store and amazon has its own OS based on Android.So the fire TV doesn't have the Amazon app store on it?Edit: it seems that although it in the Amazon app store it is not enabled for the fire tv Edited September 6, 2014 by Vidman
Deihmos 170 Posted September 6, 2014 Posted September 6, 2014 So the fire TV doesn't have the Amazon app store on it? I don't know but XBMC isn't in any store even the Google play store. These are the instructions and from what I read you need to do it again every time there is a software update. http://wiki.xbmc.org/index.php?title=Amazon_Fire_TV
bluemonkey07 590 Posted September 6, 2014 Posted September 6, 2014 (edited) As I said spmc is an android version of xbmc that is available from the Amazon app store....it is developed by a team xbmc member.... It is also mentioned in the link your provided Edited September 6, 2014 by Vidman
Deihmos 170 Posted September 6, 2014 Posted September 6, 2014 (edited) You still have to do the same procedure. Amazon app store and fire TV store are not the same. Also sbmc cannot play ac3 or dts and might have other codec restrictions. Xbmc ran into trouble with those codes which is why it was pulled from the Android store. Edited September 6, 2014 by Deihmos
breezytm 124 Posted September 6, 2014 Posted September 6, 2014 I can speak for the Fire TV since I have one and I use XBMC on it. After I installed xbmc I was having some issues. I upgraded the firmware thinking it would solve my problems. It didn't solve them but I didn't have to reinstall xbmc after the firmware update completed. Hopefully it'll be the same for Android TV.
Deihmos 170 Posted September 6, 2014 Posted September 6, 2014 (edited) I didn't say you have to reinstall xbmc. The updates can disable root so if you want to keep it rooted it is best to disable updates. Too many complications if you ask me. Edited September 6, 2014 by Deihmos
bluemonkey07 590 Posted September 6, 2014 Posted September 6, 2014 You still have to do the same procedure. Amazon app store and fire TV store are not the same. Also sbmc cannot play ac3 or dts and might have other codec restrictions. Xbmc ran into trouble with those codes which is why it was pulled from the Android store.I don't have a firetv but I have installed spmc thru Amazon app store installed on my ouya and have no problems with ac3 or dts or any other restrictions in fact spmc was created because the ouya version of xbmc was required to remove ac3 and DTS support
Scot 27 Posted September 8, 2014 Posted September 8, 2014 Root is only required if you want the Fire TV to start with the XBMC interface and not the native Fire TV interface. There are other non-root ways to have the Fire TV launch XBMC as default but the root'ed way is the nicest. In saying that if you don't mind the Fire TV interface and selecting a icon to launch XBMC than no fiddling about or rooting is required. The ROKU interface is restrictive and ugly...XBMC not only have many skins to choose from but is heavily supported by Media Browser now...having TV/Movies/Music/Pictures and Live TV all in the one spot in a fantastically beautiful unrestricted skin is very nice indeed. No issues with audio pass through for DTS and AC3 etc. is great...ability to run de-interlacing on Live TV is a must, again Fire TV/XBMC supports it... A final bonus, it'll get the WAF...it's a no brainer in my opinion...is it perfect? No...but bloodly close at the moment....
Luke 42243 Posted September 8, 2014 Posted September 8, 2014 It isn't really a fair comparison because you're putting 2014 devices and interfaces against a Roku SDK that hasn't really seen any major updates in a couple years. Not everyone likes change, particularly relating to WAF. It's only a matter of time before Roku introduces a new SDK that will level the playing field. They have a large customer base that can sustain them if they can just roll out some badly needed refreshes. Having said, if you're a first-timer, I would definitely do android tv or fire tv. if they were both available now, android tv.
Scot 27 Posted September 8, 2014 Posted September 8, 2014 (edited) Agreed, my issues with the Roku are mainly interface related (the childish nature of the skin is the ugly reference). However, does the Roku support AC3 and DTS? Can you have de-interlacing enabled for Live TV broadcasts or will have I have dreaded interlace lines? From my experience, and I admit it's not exhaustive, the Roku falls down in this areas.... Edited September 8, 2014 by Scot
