Kramerika 18 Posted April 20, 2016 Posted April 20, 2016 (edited) You still have VLC enabled? I am still direct streaming OTA signals from HDHR on my Fire TV... Yes, I have VLC enabled, and when I "Tune to Channel" from the TV guide, it shows "Transcode/L" where it used to say "Direct/V" and play a lot smoother. I did not change any settings that I know of. I will go back and reset things to see if it makes a difference. This is the same on two different Fire TV boxes connected to different TVs. Edited April 20, 2016 by Kramerika
ebr 16337 Posted April 20, 2016 Posted April 20, 2016 Yes, I have VLC enabled, and when I "Tune to Channel" from the TV guide, it shows "Transcode/L" where it used to say "Direct/V" and play a lot smoother. I did not change any settings that I know of. I will go back and reset things to see if it makes a difference. This is the same on two different Fire TV boxes connected to different TVs. Make sure the firmware on your HDHR is up to date. http://emby.media/community/index.php?/topic/33492-305927-is-transcoding-live-tv/?p=320605
Kramerika 18 Posted April 21, 2016 Posted April 21, 2016 Make sure the firmware on your HDHR is up to date. http://emby.media/community/index.php?/topic/33492-305927-is-transcoding-live-tv/?p=320605 That was it. Thanks!
ebr 16337 Posted April 21, 2016 Posted April 21, 2016 Locking this thread as it is too hard to track issues when all lumped in here. Please search the forum for your issue and, if not found, open a separate topic. Thanks.
