Kramerika 18 Posted December 4, 2015 Posted December 4, 2015 I am having an issue that I am struggling to find a solution for. I am running the Emby server and streaming to the Emby app on an Amazon Fire TV (2nd generation) through a hard-wired network. I have movies that are HD video with DTS audio and others that are SD video with AC3 audio (DD). The container is always MKV, and the video is always h.264 with the same or very similar quality. The only difference between them is the resolution, frame rate (either 23.976 or 29.97), and the audio. The HD content plays perfectly fine, but the SD content only plays the audio without the video. If I disable the built-in VLC player, it all works fine although now everything is being transcoded which I do not want if possible as I do not want the server doing unnecessary work. The frame rate does not appear to play a role. I put a few SD movies that do not work with the built-in VLC player on a USB drive to test them directly with the stand-alone VLC app, and they work fine there. It seems as though it is related to SD content and AC3 audio with the built-in VLC player. However, I do have a few anomalies. I have one movie that is SD with a DTS-ES track that works fine, another movie that is SD with a DTS track that does not play the video, and another HD movie with an AC3 track that plays fine. How can I get it to direct play the SD video with AC3 or DTS audio like the stand-alone VLC player does?
ebr 16337 Posted December 4, 2015 Posted December 4, 2015 I am having an issue that I am struggling to find a solution for. I am running the Emby server and streaming to the Emby app on an Amazon Fire TV (2nd generation) through a hard-wired network. I have movies that are HD video with DTS audio and others that are SD video with AC3 audio (DD). The container is always MKV, and the video is always h.264 with the same or very similar quality. The only difference between them is the resolution, frame rate (either 23.976 or 29.97), and the audio. The HD content plays perfectly fine, but the SD content only plays the audio without the video. If I disable the built-in VLC player, it all works fine although now everything is being transcoded which I do not want if possible as I do not want the server doing unnecessary work. The frame rate does not appear to play a role. I put a few SD movies that do not work with the built-in VLC player on a USB drive to test them directly with the stand-alone VLC app, and they work fine there. It seems as though it is related to SD content and AC3 audio with the built-in VLC player. However, I do have a few anomalies. I have one movie that is SD with a DTS-ES track that works fine, another movie that is SD with a DTS track that does not play the video, and another HD movie with an AC3 track that plays fine. How can I get it to direct play the SD video with AC3 or DTS audio like the stand-alone VLC player does? I'm not sure as I haven't seen this situation myself or reported by others. I guess you could try playing one of the problem vidoes for a few seconds and then back out and send a log (turn on debug options) but I'm afraid I'm not going to get enough information to see any errors that may be reported by VLC because it spits out so much garbage when you stop a video. Still probably worth a try. If you do that, please come back here and tell me the Emby user name that was logged in. Thx.
Kramerika 18 Posted December 4, 2015 Posted December 4, 2015 By username, do you mean the user on the server that I am using in tandem with the Fire TV app? The user profile on my server/app is "MediaServer" which is tied to my username here, "Kramerika", in the user profile settings on the server. I am using the trial version of the app right now but plan to invest in Emby Premiere once I am convinced that it will work the way that I want it to. I actually did try doing that (sending the log from the Fire TV app) last night after playing an SD movie with DTS audio that doesn't play the video. I will do it for a few more examples tonight when I get home.
ebr 16337 Posted December 4, 2015 Posted December 4, 2015 Thanks, I found your log. The one curious thing I see is this: 12-03 22:16:36.780 W/VideoCapabilities( 2154): Unrecognized profile/level 32768/2 for video/mp4v-es What does the media info on the server look like for these items?
Kramerika 18 Posted December 4, 2015 Posted December 4, 2015 (edited) Here are some examples based on the circumstances that I posted. I did not include the chapter info to cut down on the length. I created all of these files with Handbrake using the original MKV rips from my own discs using basically the same profile with a bit more compression for HD movies. I kept the original audio and subtitles while compressing the video to h.264. Here is the info for the file that I sent the log for which is an SD movie with DTS audio. General Unique ID : 304499293077671488359888453133424499210 (0xE5146E3F9F60338A2E2F3C4F0E959A0A) Complete name : F:\My Movies\Saving Private Ryan (1998).mkv Format : Matroska Format version : Version 2 File size : 5.20 GiB Duration : 2h 49mn Overall bit rate : 4 396 Kbps Writing application : HandBrake 0.9.9 Writing library : libmkv 0.6.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 49mn Bit rate : 3 554 Kbps Width : 718 pixels Height : 480 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.344 Stream size : 4.21 GiB (81%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2h 49mn Bit rate mode : Constant Bit rate : 755 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 915 MiB (17%) Language : English Default : Yes Forced : No Text ID : 3 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Language : English Default : No Forced : No Here it is for an SD movie with AC3 audio that does not work. General Unique ID : 17673236091689495466089667086082383228 (0xD4BBDD057F5FE5EFC167EDF52641D7C) Complete name : F:\My Movies\Austin Powers\Austin Powers International Man Of Mystery (1997).mkv Format : Matroska Format version : Version 2 File size : 1.72 GiB Duration : 1h 29mn Overall bit rate : 2 752 Kbps Writing application : HandBrake 0.9.9 Writing library : libmkv 0.6.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 29mn Bit rate : 2 313 Kbps Width : 712 pixels Height : 440 pixels Display aspect ratio : 1.916 Original display aspect ratio : 1.918 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.308 Stream size : 1.45 GiB (84%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 29mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 246 MiB (14%) Language : English Default : Yes Forced : No Text ID : 3 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Language : English Default : No Forced : No Here it is for the SD movie with the DTS-ES audio that works fine. General Unique ID : 115852271548623039784786350614055698610 (0x572855FCE461B4C787AD322A575340B2) Complete name : F:\My Movies\Austin Powers\Austin Powers Goldmember (2002).mkv Format : Matroska Format version : Version 2 File size : 1.65 GiB Duration : 1h 34mn Overall bit rate : 2 495 Kbps Writing application : HandBrake 0.9.9 Writing library : libmkv 0.6.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 34mn Bit rate : 1 691 Kbps Width : 720 pixels Height : 368 pixels Display aspect ratio : 2.35:1 Original display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.213 Stream size : 1.12 GiB (68%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : ES Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 34mn Bit rate mode : Constant Bit rate : 755 Kbps Channel(s) : 7 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 510 MiB (30%) Language : English Default : Yes Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : No Forced : No Here it is for the HD movie with AC3 audio that works fine. General Unique ID : 108473599548220504443902239252225669307 (0x519B415EEA40DCE8523B4A2F845F38BB) Complete name : F:\My Movies\50 First Dates (2004).mkv Format : Matroska Format version : Version 2 File size : 5.59 GiB Duration : 1h 39mn Overall bit rate : 8 075 Kbps Writing application : HandBrake 0.9.9 Writing library : libmkv 0.6.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 39mn Bit rate : 7 275 Kbps Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.198 Stream size : 5.03 GiB (90%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 39mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 453 MiB (8%) Language : English Default : Yes Forced : No Text ID : 3 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : English Default : No Forced : No And here it is for an HD movie with DTS that works. General Unique ID : 7275756988129822307645872802788023485 (0x5794283E6B432B81EFE986F77F01CBD) Complete name : F:\My Movies\Comics\Marvel\Captain America\Captain America The First Avenger (2011).mkv Format : Matroska Format version : Version 2 File size : 6.64 GiB Duration : 2h 4mn Overall bit rate : 7 659 Kbps Writing application : HandBrake 0.9.9 Writing library : libmkv 0.6.5 TITLE : Captain America The First Avenger Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 4mn Bit rate : 5 998 Kbps Width : 1 920 pixels Height : 816 pixels Display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.160 Stream size : 5.20 GiB (78%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2h 4mn Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 1.31 GiB (20%) Language : English Default : Yes Forced : No Text ID : 3 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : English Default : No Forced : No Edited December 4, 2015 by Kramerika
ebr 16337 Posted December 4, 2015 Posted December 4, 2015 Thanks but I meant in our detail display on the web client. I'm wondering if we are not able to properly determine some of the media info.
Kramerika 18 Posted December 4, 2015 Posted December 4, 2015 oh, gotcha! Let me try again. SD movie with DTS, no video Media Info Video Codec:H264 ProfileHigh: Level41 Resolution: 718x480 Aspect ratio: 16:9 Anamorphic: No Interlaced: No Framerate: 29.97003 Bitrate: 4292 kbps Bit depth: 8 bit Pixel format: yuv420p Ref frames: 4 CABAC: Yes Audio Languag: eeng Codec: DCA Profile: DTS Layout: 5.1 Channels: 6 ch Bitrate: 750 kbps Sample rate: 48000 khz Default: Yes Subtitle Language: eng Codec: DVDSUB Default: No Forced: No External: No Container: mkv Path\\MEDIASERVER-PC\My Movies\Saving Private Ryan (1998).mkv SD movie with AC3, no video Media Info Video Codec: H264 Profile: High Level: 41 Resolution: 712x440 Aspect ratio: 13172:6875 Anamorphic: No Interlaced: No Framerate: 23.97602 Bitrate: 2687 kbps Bit depth: 8 bit Pixel format: yuv420p Ref frames: 4 CABAC: Yes Audio Language: eng Codec: AC3 Layout: 5.1 Channels: 6 ch Bitrate: 375 kbps Sample rate: 48000 khz Default: Yes Subtitle Language: eng Codec: DVDSUB Default: No Forced: No External: No Container: mkv Path\\MEDIASERVER-PC\My Movies\Austin Powers\Austin Powers International Man Of Mystery (1997).mkv SD movie with DTS-ES, video works Media Info Video Codec: H264 Profile: High Level: 41 Resolution: 720x368 Aspect ratio: 8370:3611 Anamorphic: No Interlaced: No Framerate: 29.97003 Bitrate: 2436 kbps Bit depth: 8 bit Pixel format: yuv420p Ref frames: 4 CABAC: Yes Audio Language: eng Codec: DCA Profile: DTS-ES Layout: 6.1 Channels: 7 ch Bitrate: 750 kbps Sample rate: 48000 khz Default: Yes Subtitle Language: eng Codec: SRT Default: No Forced: No External: No Container: mkv Path\\MEDIASERVER-PC\My Movies\Austin Powers\Austin Powers Goldmember (2002).mkv HD movie with AC3, video works Media Info Video Codec: H264 Profile: High Level: 41 Resolution: 1920x800 Aspect ratio: 2.40:1 Anamorphic: No Interlaced: No Framerate: 23.97602 Bitrate: 7886 kbps Bit depth: 8 bit Pixel format: yuv420p Ref frames: 4 CABAC: Yes Audio Language: eng Codec: AC3 Layout: 5.1 Channels: 6 ch Bitrate: 625 kbps Sample rate: 48000 khz Default: Yes Subtitle Language: eng Codec: PGSSUB Default: No Forced: No External: No Container: mkv Path\\MEDIASERVER-PC\My Movies\50 First Dates (2004).mkv HD movie with DTS, video works Media Info Video Codec: H264 Profile: High Level: 41 Resolution: 1920x816 Aspect ratio: 2.35:1 Anamorphic: No Interlaced: No Framerate: 23.97602 Bitrate: 7479 kbps Bit depth: 8 bit Pixel format: yuv420p Ref frames: 4 CABAC: Yes Audio Language: eng Codec: DCA Profile: DTS Layout: 5.1 Channels: 6 ch Bitrate: 1500 kbps Sample rate: 48000 khz Default: Yes Subtitle Language: eng Codec: PGSSUB Default: No Forced: No External: No Container: mkv Path\\MEDIASERVER-PC\My Movies\Comics\Marvel\Captain America\Captain America The First Avenger (2011).mkv
ebr 16337 Posted December 4, 2015 Posted December 4, 2015 Well, I can't see anything obvious there. Not sure why VLC is having trouble. Sorry.
Kramerika 18 Posted December 5, 2015 Posted December 5, 2015 (edited) Bummer. I wonder why the stand-alone VLC app for the Fire TV plays them fine? I also can play everything on my Nexus 7 with the Android Emby app without transcoding. I might try an Nvidia Shield TV at some point. I sent a few more logs for good measure just in case it was helpful. Edited December 5, 2015 by Kramerika
Kramerika 18 Posted December 10, 2015 Posted December 10, 2015 A small update on this. Almost everything seems to work without using the built-in VNC player and transcoding. There is one exception. The movie about that is SD but with DTS-ES sound hangs the app. It sits and spins, and I have to hit the menu button to exit the app. If I could get it to generate a log, I would send it, but it seems that when it crashes, the log disappears. Hopefully I will be able to direct play everything with a future update as I really don't like to transcode. Is there any way to speed up the app loading content when you start it up? It is sluggish. Once everything loads, it's pretty snappy. I am on a wired GB connection, and the server is 64-bit Windows 7 with an Intel i7 and 6 GBs of RAM. Also, I was wondering if it was normal for some of the actors/actresses images to be missing? I tried to update the people on the server, but that didn't help.
ebr 16337 Posted December 10, 2015 Posted December 10, 2015 I've never heard anyone say this app is sluggish. Mine produces a full home screen in about 1/8th of a second. Are you sure you don't have something like a drive needing to be woken up or something?
Kramerika 18 Posted December 11, 2015 Posted December 11, 2015 No, it is always on. It is a WD Green 5400 RPM 4 TB drive. It's possible that a faster drive would help, but I didn't think it would make that big of an impact. It takes more like 15-30 seconds for everything to load on startup for me. Once it all loads, navigating is fine.
CBers 7554 Posted December 11, 2015 Posted December 11, 2015 No, it is always on. It is a WD Green 5400 RPM 4 TB drive. It's possible that a faster drive would help, but I didn't think it would make that big of an impact. It takes more like 15-30 seconds for everything to load on startup for me. Once it all loads, navigating is fine. Do you get any "(slow)" messages in the server log in relation to the devices IP address? I used to have slow propagation of the different rows, especially Next Up, but it's very pretty slick lately.
ebr 16337 Posted December 11, 2015 Posted December 11, 2015 Green drives do automatically sleep but that's not necessarily the problem. Just one possibility.
Kramerika 18 Posted December 11, 2015 Posted December 11, 2015 In doing some searching, it seems that there might be a way to turn off the sleeping feature, but it's not straight-forward. I'll have to look into it further, try it out, and report back. Otherwise, I might try a black drive instead. I do get some "(slow)" messages in the log. They are from 1000 up to almost 70000 ms. The IP address associated with this is primarily my Amazon Fire TV (wired) or my Nexus 7 tablet (wireless), which are what I have been using to test, although there are a few entries for the server IP or from 127.0.0.1. I set static IP addresses on all of my devices. I don't know what to copy from the log. Here is a section with a slow message. 2015-12-10 14:38:06.7128 Info HttpServer: HTTP Response 200 to 192.168.1.80. Time: 28956ms (slow). http://192.168.1.97:8096/emby/Users/7b70166e63c04c3d9b642d1194e8f71b/Items?Years=&EnableImageTypes=&ArtistIds=&Filters=IsUnplayed&Fields=PrimaryImageAspectRatio%2COverview%2CItemCounts%2CDisplayPreferencesId&Genres=&MediaTypes=&Ids=&PersonTypes=&recursive=true&ExcludeLocationTypes=&ExcludeItemTypes=&AirDays=&sortOrder=Descending&Limit=50&SortBy=DateCreated&StudioIds=&PersonIds=&ImageTypes=&IncludeItemTypes=Movie&VideoTypes=&LocationTypes=&SeriesStatuses=&format=json 2015-12-10 14:38:06.7128 Info HttpServer: HTTP Response 200 to 192.168.1.80. Time: 29346ms (slow). http://192.168.1.97:8096/emby/Users/7b70166e63c04c3d9b642d1194e8f71b/Items?Years=&EnableImageTypes=&ArtistIds=&Filters=IsResumable&Fields=PrimaryImageAspectRatio%2COverview%2CItemCounts%2CDisplayPreferencesId&Genres=&MediaTypes=&Ids=&PersonTypes=&recursive=true&ExcludeLocationTypes=&ExcludeItemTypes=&AirDays=&sortOrder=Descending&Limit=2&SortBy=DatePlayed&StudioIds=&PersonIds=&ImageTypes=&IncludeItemTypes=Movie&VideoTypes=&LocationTypes=&SeriesStatuses=&format=json 2015-12-10 14:38:06.7284 Info HttpServer: HTTP GET http://192.168.1.97:8096/emby/Shows/NextUp?EnableImageTypes=&Limit=50&UserId=7b70166e63c04c3d9b642d1194e8f71b&Fields=PrimaryImageAspectRatio%2COverview&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 5.1; AFTS Build/LMY47O) 2015-12-10 14:38:06.7284 Info HttpServer: HTTP GET http://192.168.1.97:8096/emby/LiveTv/Programs/Recommended?IsAiring=true&Limit=20&UserId=7b70166e63c04c3d9b642d1194e8f71b&Fields=Overview%2CPrimaryImageAspectRatio%2CChannelInfo&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 5.1; AFTS Build/LMY47O) 2015-12-10 14:38:06.7440 Debug SqliteItemRepository: select type,data,StartDate,EndDate,IsOffline,ChannelId,IsMovie,IsSports,IsKids,IsSeries,IsLive,IsNews,IsPremiere,EpisodeTitle,IsRepeat,CommunityRating,CustomRating,IndexNumber,IsLocked,PreferredMetadataLanguage,PreferredMetadataCountryCode,IsHD,ExternalEtag,DateLastRefreshed from TypedBaseItems where type=@type AND StartDate<=@MaxStartDate AND EndDate>=@MinEndDate; select count (guid) from TypedBaseItems where type=@type AND StartDate<=@MaxStartDate AND EndDate>=@MinEndDate 2015-12-10 14:38:06.7752 Debug SsdpHandler: NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age=100 LOCATION: http://192.168.1.5:49152/description.xml NT: urn:schemas-wifialliance-org:device:WFADevice:1 NTS: ssdp:alive SERVER: Linux/2.6.36, UPnP/1.0, Portable SDK for UPnP devices/1.3.1 X-User-Agent: redsonic USN: uuid:28802880-2880-1880-a880-6cb0ce137f79::urn:schemas-wifialliance-org:device:WFADevice:1 While searching the log, I found this entry which is when I tried to play the SD movie with the DTS-ES track that played fine directly with the built-in VLC player but now won't play when transcoding. 2015-12-10 14:53:15.5989 Info HttpServer: HTTP Response 500 to 192.168.1.80. Time: 68984ms (slow). http://192.168.1.97:8096/emby/videos/db57efcb6b130e92d68eaf009f9a7872/hls1/main/0.ts?DeviceId=a96353d314840f77&MediaSourceId=db57efcb6b130e92d68eaf009f9a7872&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=39680000&AudioBitrate=320000&MaxAudioChannels=8&MaxWidth=8688&Level=51&ClientTime=1449777103736&MaxVideoBitDepth=8&Profile=high&PlaySessionId=11d62f5fde174d7897f0bf3144f5f411&api_key=065ca266c87e46fea00fbd01dc3af151 2015-12-10 14:53:15.9265 Info HttpServer: HTTP GET http://192.168.1.97:8096/emby/videos/db57efcb6b130e92d68eaf009f9a7872/hls1/main/0.ts?DeviceId=a96353d314840f77&MediaSourceId=db57efcb6b130e92d68eaf009f9a7872&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=39680000&AudioBitrate=320000&MaxAudioChannels=8&MaxWidth=8688&Level=51&ClientTime=1449777103736&MaxVideoBitDepth=8&Profile=high&PlaySessionId=11d62f5fde174d7897f0bf3144f5f411&api_key=065ca266c87e46fea00fbd01dc3af151. UserAgent: Fire OS/5.0.3.1 stagefright/1.2 (Linux;Android 5.1) 2015-12-10 14:53:15.9265 Debug App: Cannot stream copy video due to missing keyframe info 2015-12-10 14:53:15.9265 Debug App: Starting transcoding because currentTranscodingIndex=null 2015-12-10 14:53:15.9265 Info App: C:\Users\Media Server\AppData\Roaming\Emby-Server\ffmpeg\20151111\ffmpeg.exe -i file:"F:\My Movies\Austin Powers\Austin Powers Goldmember (2002).mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -b:v 2494673 -maxrate 2494673 -bufsize 4989346 -vsync vfr -profile:v high -level 51 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -flags -global_header -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 7 -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -y "F:\Transcoding\transcoding-temp\d8ef39e1310934f621ee208fb0dbe982.m3u8" 2015-12-10 14:53:19.8110 Debug App: Disposing stream resources 2015-12-10 14:53:19.8110 Info App: FFMpeg exited with code 1 2015-12-10 14:53:19.8266 Debug SsdpHandler: M-SEARCH * HTTP/1.1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" MX: 1 ST: urn:dial-multiscreen-org:service:dial:1 USER-AGENT: Google Chrome/47.0.2526.80 Windows I also noticed that it is False in the server log for a 64-bit process. How can I get it to be 64-bit?
jluce50 122 Posted December 11, 2015 Posted December 11, 2015 In doing some searching, it seems that there might be a way to turn off the sleeping feature, but it's not straight-forward. I'll have to look into it further, try it out, and report back. Otherwise, I might try a black drive instead. I wasn't able to use the wdidle3 utility for some reason (it was a while ago), but I was able to use this tool. I had to create a bootable linux flash drive and run it from there, but it worked perfectly. It's a bit of a hassle, but it's pretty straight-forward and worth it in the long run IMO.
Kramerika 18 Posted December 11, 2015 Posted December 11, 2015 Thanks! I'll try that. Did you disable the timer completely or set it to 300 seconds? In some of my searching, it was mentioned a few times that disabling it completely can cause problems and that 300 seconds was a better option.
jluce50 122 Posted December 11, 2015 Posted December 11, 2015 You know, I honestly don't remember. I think I set it to 300, but I could be wrong.
taxion 0 Posted December 12, 2015 Posted December 12, 2015 (edited) Using the search feature i was unable to resolve my problem. (So i'm forced to make my first post, been running "emby" since 2012. Set up. Emby server on a dedicated windows 7 machine. All files in library are stored one of two NAS (drobo5N). playback of HD (mostly H264) content is flawless and plays directly. However, anything encoded in MPEG2 also wants to play directly and the FTV does not support direct playback of MPEG2. If i uncheck VLC in the setting everything plays but everything is transcoded. Transcoding is quick but quality of content that can be played directly is degraded. Is transcoding on the fire all or nothing? Suggestion on play direct h264 and transcode h263? Edited December 12, 2015 by taxion
ebr 16337 Posted December 12, 2015 Posted December 12, 2015 Using the search feature i was unable to resolve my problem. (So i'm forced to make my first post, been running "emby" since 2012. Set up. Emby server on a dedicated windows 7 machine. All files in library are stored one of two NAS (drobo5N). playback of HD (mostly H264) content is flawless and plays directly. However, anything encoded in MPEG2 also wants to play directly and the FTV does not support direct playback of MPEG2. If i uncheck VLC in the setting everything plays but everything is transcoded. Transcoding is quick but quality of content that can be played directly is degraded. Is transcoding on the fire all or nothing? Suggestion on play direct h264 and transcode h263? What actually happens when you try to play one of the mpg-2 items? What does the media info look like in the server?
taxion 0 Posted December 12, 2015 Posted December 12, 2015 (edited) I get the spinning wheel, but it doesn't crash. I can press back and return to folder. Video CodecMPEG2VIDEOProfileMainLevel8Resolution720x480Aspect ratio16:9AnamorphicNoInterlacedNoFramerate29.66667Bitrate7817 kbpsBit depth8 bitPixel formatyuv420pRef frames1 Audio CodecAC3Layout5.1Channels6 chBitrate437 kbpsSample rate48000 khzDefaultNo Containervob Path\\xxxxx\xxxx2\Animated\Barbie & Her Sisters in the Great Puppy Adventure (2015) [unknown] [NR] [voted 6.6] [Family-Animation]\Barbie & Her Sisters in the Great Puppy Adventure (2015) [unknown] [NR] [voted 6.6] [Family-Animation].vob Edited December 12, 2015 by taxion
ebr 16337 Posted December 12, 2015 Posted December 12, 2015 Ah, a .vob file... And the OSD says "Direct/V"? Luke, should the VLC profile be transcoding a VOB?
taxion 0 Posted December 12, 2015 Posted December 12, 2015 using tsmuxer i changed the container to a .ts. It plays but says it's direct/v, which i doubt. it looks transcoded and should be.
ebr 16337 Posted December 12, 2015 Posted December 12, 2015 using tsmuxer i changed the container to a .ts. It plays but says it's direct/v, which i doubt. it looks transcoded and should be. Why do you doubt it? I'm sure it is direct streaming it and VLC is just decoding it locally.
