Seger 123 Posted July 18, 2018 Posted July 18, 2018 (edited) Hey my friend, @@Angelblue05 have since the last version and the current a strange behavior in Kodi. @@sualfred already told me that it is not the skin and I should contact you. Everything is up to date, the server does it right but Kodi behaves weird. And when I start a movie, a local trailer starts before me (correctly named and read - metadata have already been deleted and completely replaced). But after the passage of the trailer does not start the main movie but it is finished and the main movie is marked as seen. But if I do not start the movie in Kodi directly via the widget or from my library, but go the detour "i" and in the information screen on "Watch Now", the trailer starts and then the movie (which is correct). If I finish this immediately, then he is also "not seen". adjusted everything correctly in the plugin Send me the log, where I have both variants in it. Do you perhaps see the mistake? Thanks and best regards Seger Edited July 18, 2018 by Seger
Angelblue05 4132 Posted July 18, 2018 Posted July 18, 2018 I see an error in your log. I'll have a look. Can you play the main movie if you disable play trailers in the add-on settings > playback?
Seger 123 Posted July 19, 2018 Author Posted July 19, 2018 (edited) Hey buddy, @@Angelblue05 yes, I can, as soon as I turn off the function, I can start the movie on any menu without problems. Well, at least you've already seen something, if you still need logs, then I can do that today until 12 o'clock, otherwise he will be back on Monday, then I'll be at a festival ;-). Thanks and best regards Seger Edited July 19, 2018 by Seger
Seger 123 Posted July 24, 2018 Author Posted July 24, 2018 Moin buddy, @@Angelblue05 I just wanted to report back to you shortly. If you need more information, help or test, I am at your disposal. Best regards Seger
Angelblue05 4132 Posted July 25, 2018 Posted July 25, 2018 (edited) In the next beta. Thanks for your patience. Edit: If it's still not corrected. Can you check your server. For some reason it's throwing error 500 (which usually indicates a server issue). Edited July 28, 2018 by Angelblue05
