lupacexi 1 Posted July 18, 2018 Posted July 18, 2018 hello, my laptop is a bit slow compared to my work needs. So I decided to add more ram to it. hmm i have an extra ram from my old laptop. I decided to install it but after reboot I did not see that ram in my laptop. I do not know how to do it. I need some help.hello, my laptop is a bit slow compared to my work needs. So I decided to add more ram to it. hmm i have an extra ram from my old laptop. I decided to install it but after reboot I did not see that ram in my laptop. I do not know how to do it. I need some help.
dcrdev 255 Posted July 18, 2018 Posted July 18, 2018 - Are you sure the additional module is compatible i.e. under or equal to the recommended speed and/or the size of the module is supported by your chipset. - Are you sure that it's properly seated i.e. the module aligns evenly and all contacts are sufficiently embedded in the socket? - Have you tried resetting your cmos either a) via bios via the jumpers on the motherboard?
maegibbons 1287 Posted July 21, 2018 Posted July 21, 2018 In terms of speed - have you got an SSD in your laptop? If not, GET ONE, that will give you the biggest performance gain. Krs Mark
