Trevor68 70 Posted July 19, 2018 Posted July 19, 2018 Mine did.. I set it and forget it. About 6 hours later I came back and it was up and running but loading on the apps is taking a while there too as it seems to be rebuilding data there too but I'm not sure. Same except mine took 18 hours, and still unresponsive the next time a scan starts.
invertedknife 13 Posted July 19, 2018 Posted July 19, 2018 (edited) Yes, probably just due to the library scan and nothing associated with the release. Thanks. nope that didn't fix it. logs attached playing stuff is superslow and that's for local, can't stream anything 2018-07-19 19:28:18.813 Info HttpServer: HTTP Response 200 to ::1. Time: 46294ms (slow). http://localhost:8096/emby/Shows/8820acadff35975dc5943236d33fa386/Episodes?IsVirtualUnaired=false&IsMissing=false&UserId=c8c517cd3777bbb9d9f32869e92b0461&Fields=Chapters New Text Document (2).txt Edited July 19, 2018 by invertedknife
Luke 42212 Posted July 20, 2018 Posted July 20, 2018 Can you try removing the cover art plugin and see if this improves the performance of the server? thanks !
chef 3811 Posted July 21, 2018 Posted July 21, 2018 @@chef How to use iptv to view surveillance cameras? Thanks. You'll have to find the rstp URL for the camera, then make sure there is no credentials on the stream (dangerous because now it's open to whatever) Then copy the URL into the iptv plugin configuration. I still have my old security camera plugin if you want it. Pm me.
Sammy 791 Posted July 21, 2018 Author Posted July 21, 2018 You'll have to find the rstp URL for the camera, then make sure there is no credentials on the stream (dangerous because now it's open to whatever) Then copy the URL into the iptv plugin configuration. I still have my old security camera plugin if you want it. Pm me. IIR, your plugin allows for credentials to be saved? Does it still work under Emby Server 3.5.0.0? Sent from my SM-G930P using Tapatalk
chef 3811 Posted July 21, 2018 Posted July 21, 2018 IIR, your plugin allows for credentials to be saved? Does it still work under Emby Server 3.5.0.0? Sent from my SM-G930P using Tapatalk Yeah still works, but the same issue presents itself, can't have credentials in the rstp stream. But, should be okay as long as you don't open those rstp ports to the Internet. Pretty sure you router/modem firewall will protect your sub net ips.
