Marc_G 95 Posted July 17, 2018 Posted July 17, 2018 Hi all, I don't use my Roku stick much, but was getting it set up for some vacation travel. For the first time I put the Emby app on it, and connected it to my server. I never did this before. While it seems to work fine, the list of movies suffers from a major aspect ratio fail. This is clearly a minor cosmetic issue, but is it fixable? Here is a picture: Thanks folks! Marc
Marc_G 95 Posted July 17, 2018 Author Posted July 17, 2018 PS: I didn't grab the log at the time I did this, but if logs will help I will unpack the Roku, repeat the process, and upload a log.
Marc_G 95 Posted July 17, 2018 Author Posted July 17, 2018 I was afraid somebody would ask that. Well, Emby Server is 3.4.1.0 (yes, I know there's an update waiting for me...). The Roku stick has been sitting in a box since last August. When I set it up last week to test it out, first the Roku itself updated itself to presumably the latest version, then I added the Emby app so it is presumably current as of Friday or Saturday, whenever I messed with it. I'm getting the feeling I need to reproduce and capture the log....
Happy2Play 9811 Posted July 17, 2018 Posted July 17, 2018 Possibly or the app just needs updating to the current version.
Marc_G 95 Posted July 18, 2018 Author Posted July 18, 2018 Thanks guys. No time tonight, and may not get to it before vacation. Eventually I will investigate and if it continues, will report back. It's just a cosmetic thing so not a big deal.
ebr 16335 Posted July 18, 2018 Posted July 18, 2018 What is the type of that library? Is it movies or home videos?
Marc_G 95 Posted July 19, 2018 Author Posted July 19, 2018 EDIT: The library content type that shows a problem is Mixed Content. I actually don't have any libraries in use that are Movies. I do have several TV Shows type libraries, and these display with correct aspect ratios. I checked multiple Mixed Content libraries; they are all stretchy. The Emby server version is now updated to 3.5.0.0 this evening, and the Roku app was I believe 3.0.8.4 (or was it 3.0.84?) that showed before everything finished setting up when I went in and connected. I'm attaching a log, starting I believe with when Emby started up after the update, and going through me playing around with the Roku just now. Note I had an aborted attempt to play Pirates of the Caribbean... it hung on the first attempt. Second attempt started fine. Not sure what that was about. Again, stretchy icons I can live with; it's just a cosmetic thing, now duly reported. :-) Marc embyserver.txt
Happy2Play 9811 Posted July 19, 2018 Posted July 19, 2018 @@ebr Not positive it there was a update for this in the beta app channel. Can't test Mixed/unset library right now.
Happy2Play 9811 Posted July 19, 2018 Posted July 19, 2018 Okay beta .88 has the same issue with Folder/Mixed/Unset libraries. Image in post #1. 1
