heciruam 30 Posted December 8, 2023 Posted December 8, 2023 Will these new playlists be also visible in Collections?
Luke 42245 Posted January 8, 2024 Posted January 8, 2024 On 12/8/2023 at 4:52 PM, heciruam said: Will these new playlists be also visible in Collections? What do you mean exactly?
heciruam 30 Posted January 9, 2024 Posted January 9, 2024 Sorry I phrased that wrong. Will it be possible to add playlists to collections? So not the items in the playlist but the playlist itself?
Luke 42245 Posted January 9, 2024 Posted January 9, 2024 3 hours ago, heciruam said: Sorry I phrased that wrong. Will it be possible to add playlists to collections? So not the items in the playlist but the playlist itself? You already can.
JohnnyThe5th 4 Posted January 27, 2024 Posted January 27, 2024 My brother just created a playlist for the first time and now everyone sees it. I was quite confused but lucky this is the first that it came up for us. Do we expect this new playlist management feature to be rolled out with 4.8 stable?
HouseOfCards 95 Posted January 27, 2024 Posted January 27, 2024 From what I've read, the feature and management of who can see the newly created playlists will be available in the 4.8 release. If I recall correctly, you will only be able to set the permission on new playlists you create with the new 4.8 server, so if you create one on 4.7, you won't be able to edit the permission for it on 4.8.
MDMEDIA 4 Posted February 27, 2024 Posted February 27, 2024 Has something changed here?.....when I first moved to 4.8 I could could create a playlist and then configure it to be private or public. I'm running 4.8.1and I now no longer seem to have the option to do this, I can create new and name it, that's all. My head is spinning as I can't understand why!
Luke 42245 Posted February 27, 2024 Posted February 27, 2024 1 hour ago, MDMEDIA said: Has something changed here?.....when I first moved to 4.8 I could could create a playlist and then configure it to be private or public. I'm running 4.8.1and I now no longer seem to have the option to do this, I can create new and name it, that's all. My head is spinning as I can't understand why! Hi, make sure your user is granted permission to share personal content.
MDMEDIA 4 Posted February 27, 2024 Posted February 27, 2024 33 minutes ago, Luke said: Hi, make sure your user is granted permission to share personal content. Hi Luke, thanks for your reply. I am the server administrator and I have all permissions. I've just double checked and still cannot seem to be able to configure playlists between public and private. I've not changed anything other than version from 4.8 stable to 4.8.1.0 Should the option to edit the playlist be in the context menu or somewhere else? When I've create a new playlist, it asks me to name it and then nothing after.
Luke 42245 Posted February 27, 2024 Posted February 27, 2024 11 minutes ago, MDMEDIA said: Hi Luke, thanks for your reply. I am the server administrator and I have all permissions. I've just double checked and still cannot seem to be able to configure playlists between public and private. I've not changed anything other than version from 4.8 stable to 4.8.1.0 Should the option to edit the playlist be in the context menu or somewhere else? When I've create a new playlist, it asks me to name it and then nothing after. Did you locate the permission for sharing personal content?
Carlo 4561 Posted February 29, 2024 Posted February 29, 2024 Hi @MDMEDIA This is from the Profile tab when editing a user at the bottom of the page. You need to make sure the high lighted option above is enabled. This goes for every user you want to be able to share content. Even a user with server management rights (admin), needs to have this enabled. Hope this helps, Carlo
rigo8582 16 Posted March 3, 2024 Posted March 3, 2024 Are playlists private by default private? Is there an option to make a user's playlists automatically public when its created?
Happy2Play 9812 Posted March 3, 2024 Posted March 3, 2024 21 minutes ago, rigo8582 said: Are playlists private by default private? Is there an option to make a user's playlists automatically public when its created? Yes the creator controls the playlist. Now the setting is twofold. Admin-app settings-Users-the user and once created the Collaboration option on the playlist item menu
rigo8582 16 Posted March 3, 2024 Posted March 3, 2024 48 minutes ago, Happy2Play said: Yes the creator controls the playlist. Now the setting is twofold. Admin-app settings-Users-the user and once created the Collaboration option on the playlist item menu Yes I understand all that and have all that enabled. So there isn't a way to make it be collaborative by default when its created? Meaning not having to do that every time a playlist is created if user prefers.
Happy2Play 9812 Posted March 3, 2024 Posted March 3, 2024 22 minutes ago, rigo8582 said: Yes I understand all that and have all that enabled. So there isn't a way to make it be collaborative by default when its created? Meaning not having to do that every time a playlist is created if user prefers. No there is no default to make everything public. So all playlists are private per user, requiring Collaboration setting. Not saying devs can't add options later but currently they are default private. 1
Armageus 78 Posted March 4, 2024 Posted March 4, 2024 6 years late and then ends up being overly complicated and still not delivering everything everyone wanted
Luke 42245 Posted March 4, 2024 Posted March 4, 2024 4 minutes ago, Armageus said: 6 years late and then ends up being overly complicated and still not delivering everything everyone wanted Hi, what do you find complicated about it?
Armageus 78 Posted March 5, 2024 Posted March 5, 2024 10 hours ago, Luke said: Hi, what do you find complicated about it? In fairness I've not even upgraded to 4.8.x.x yet, I'll wait for another couple of releases for all the regressions to be sorted out. (I also got so bored of waiting for public playlists that it's no longer the pressing issue for me that it once was). As to what is complicated - not necessarily complicated, but needlessly clunky. First you have to tick a box to allow sharing? And then there's a whole manage collaboration page, when a simple public/private would have done for most use cases (personally can't see a use case where you would share a playlist with just 1 person)
ebr 16337 Posted March 5, 2024 Posted March 5, 2024 5 hours ago, Armageus said: First you have to tick a box to allow sharing? Hi. This is necessary in this day and age for privacy reasons. 5 hours ago, Armageus said: And then there's a whole manage collaboration page, when a simple public/private would have done for most use cases So, we have too much functionality? 5 hours ago, Armageus said: personally can't see a use case where you would share a playlist with just 1 person This was very highly requested during beta. The use case is probably more that there are a few users you may not want to share with. 2
Luke 42245 Posted March 5, 2024 Posted March 5, 2024 8 hours ago, Armageus said: In fairness I've not even upgraded to 4.8.x.x yet, I'll wait for another couple of releases for all the regressions to be sorted out. (I also got so bored of waiting for public playlists that it's no longer the pressing issue for me that it once was). As to what is complicated - not necessarily complicated, but needlessly clunky. First you have to tick a box to allow sharing? And then there's a whole manage collaboration page, when a simple public/private would have done for most use cases (personally can't see a use case where you would share a playlist with just 1 person) Hi, there is simple public and private. You don’t have to do anything beyond that if you don’t want to. 1
rigo8582 16 Posted March 21, 2024 Posted March 21, 2024 (edited) Could you consider making an option to where someone make a specific user makes a playlist its automatically collaborative? Having to do that with every playlist is tedious. Or even the ability to select multiple playlists to have the option to make them collaborative. Edited March 21, 2024 by rigo8582 1
Luke 42245 Posted March 29, 2024 Posted March 29, 2024 On 3/21/2024 at 1:53 PM, rigo8582 said: Could you consider making an option to where someone make a specific user makes a playlist its automatically collaborative? Having to do that with every playlist is tedious. Or even the ability to select multiple playlists to have the option to make them collaborative. Hi, yes there are multiple routes to consider to make it easier to handle for multiple playlists. 1
Junglejim 385 Posted March 29, 2024 Posted March 29, 2024 (edited) @LukeMate.. don't you find this forum a bit soul destroying at times? You've done your best but peeps still want more. Sure there are some bugs with big changes. I guess it's more of a reflection on today's society . GO TRUMP Edited March 29, 2024 by Junglejim
scott46953 31 Posted March 30, 2024 Posted March 30, 2024 Someone on topic, I was thinking of something similar to this couple weeks ago... Customizable TV channel lists. Example.. I have channels ranging from Channel 1.1 through 59.4 I also have channels ranging from 100 all the way up to 70,000.. Of course it's going to take or it would be nearly impossible for somebody to scroll through all those channels or if they did they would spend all day doing it.. So, I thought wouldn't it be nice if I had a customizable shareable channel list that is selectable by each user. Selection #1 Show all Selection #2 DTV Selection #3 Cable TV And so on... 1
Kwick 8 Posted November 15, 2024 Posted November 15, 2024 On 3/4/2024 at 3:37 PM, Armageus said: 6 years late and then ends up being overly complicated and still not delivering everything everyone wanted Typical lmao. I'm new here to Emby and every idea I've tried to research and see if it's been brought up yet and every one of them were brought up like 6 years ago and still not implemented. Seems like a reoccurring theme shame because I actually considered spending money on lifetime premium. 1
