Goodvibes 0 Posted July 17, 2018 Posted July 17, 2018 I have just installed Emby premiere and I have a HDHomerun HDRH3-DT. The installation seemed to go fine. It detected my tuner, I added the EPG but when I click a program or station to watch all that happens is I get a spinning circle on the screen. The tuner works fine in other programs. I have searched extensively on the net and this problem doesn't seem to be widespread so it must be me I guess... sigh. I have attached a log. Thanks for any help.
Luke 42213 Posted July 17, 2018 Posted July 17, 2018 Hi there, did you forget to attach the log? Thanks !
mastrmind11 722 Posted July 17, 2018 Posted July 17, 2018 HttpServer: Access token is invalid or expired.
Luke 42213 Posted July 17, 2018 Posted July 17, 2018 Yea i don't actually see any playback attempts here. Are you sure you've logged into your Emby web interface?
Goodvibes 0 Posted July 18, 2018 Author Posted July 18, 2018 When I get home I'll retry this. Is there a text string in the logs that is a flag for this? I can then check before resending the log. Thanks.
Goodvibes 0 Posted July 18, 2018 Author Posted July 18, 2018 I have attached logs from just after re-starting the server and a screenshot of the LiveTV setup page. The tuner was detected when I installed the software but no channels are listed. I couldn't find in the Wiki whether this was normal. If I try and watch a channel from the guide in the web client a coloured circle just spins continuously. As I said, the tuners are accessible in VLC etc. This is interesting, I just tried accessing the tuner in VLC and it said it was in use by my PC. Maybe Emby was 'trying' to access it? Log.txt Log1.txt
Goodvibes 0 Posted July 19, 2018 Author Posted July 19, 2018 OK, today it started working. I didn't really do anything though, which is slightly disconcerting. One issue still is that it only seems to see 2 of my tuners. I have 2 dual HDHRs and I can only record programs on 2 channels before I get the 'ring of death' which I presume means there are no channels available.
maegibbons 1287 Posted July 19, 2018 Posted July 19, 2018 Can you add a new log? Does emby show the two tuner units on the Live TV tab on the admin page? Are both IPs correct? Krs Mark
Luke 42213 Posted September 6, 2018 Posted September 6, 2018 hi @@Goodvibes, this info might be helpful: https://emby.media/community/index.php?/topic/62232-hdhomerun-on-windows-server-2016/?p=616974 Please let us know if this helps. Thanks !
