Volfan6415 19 Posted October 1, 2018 Posted October 1, 2018 Any update? Work around betas to try? Cause of the issue? I am also seeing this on my fire tablet. The only way i can keep a sync going and not have it create the multiple files is to have the app stay open by playing a file while the sync is running.
Luke 42244 Posted October 1, 2018 Posted October 1, 2018 We are working on re-working the downloading in the app to resolve this, thanks.
Luke 42244 Posted October 14, 2018 Posted October 14, 2018 There is a beta release available, 3.0.18, and it has the fix for this. Please reconfigure your download settings. Thanks.
Riccardo 0 Posted October 14, 2018 Posted October 14, 2018 The actual downloads seem a lot more reliable now, thanks! I didn't realise they were actually working until I saw that they were going through the native Android download notifications now. One issue is that my only option in the settings is to download to 'internal storage'. These show up in the Android file manager, and from there I can share to MX Player. But wherever they're saving to doesn't appear to be a path I can add within MX Player itself.
Luke 42244 Posted October 14, 2018 Posted October 14, 2018 You're not going to be able to configure the download folder anymore, it's either a simple internal or external selection. That is the price of improving download stability.
Riccardo 0 Posted October 14, 2018 Posted October 14, 2018 That's fine, I can always move the files manually if necessary. Where are the files actually stored, somewhere within Emby's folder structure? I notice the downloaded filenames have changed, it's now just the episode title without the show name and episode number - would it be possible to change this, or make it configurable? One other thing I noticed in the playback settings, the values for the skip navigation dropdowns are all 'ValueSeconds'. Happy to open a new thread for this if it helps.
alton987 1 Posted October 15, 2018 Posted October 15, 2018 Can I recommend a clear all downloads and sync option? I had the issue in the thread and I'm re downloading everything and trying to get it working again. I found a lot of errors on the attached page. It would be nice to have a clear all option instead of removing line by line.
Luke 42244 Posted October 15, 2018 Posted October 15, 2018 Yes we need to revamp the management screens. Thanks.
AdilMahboob 4 Posted October 15, 2018 Posted October 15, 2018 Where are the files actually stored, somewhere within Emby's folder structure? Assuming you've got Internal Storage selected, it's in Internal Storage > Android > data > com.mb.android > files > sync
Luke 42244 Posted October 15, 2018 Posted October 15, 2018 Right, that's the app's designated internal storage area.
AdilMahboob 4 Posted October 15, 2018 Posted October 15, 2018 You're not going to be able to configure the download folder anymore, it's either a simple internal or external selection. That is the price of improving download stability. What's the criteria for External Storage being available as an option? Emby isn't giving me the option as all I see is Internal Storage. There's definitely external storage in the phone that Emby used to be able to see. I've double checked it has permissions for storage as well.
Luke 42244 Posted October 15, 2018 Posted October 15, 2018 What's the criteria for External Storage being available as an option? Emby isn't giving me the option as all I see is Internal Storage. There's definitely external storage in the phone that Emby used to be able to see. I've double checked it has permissions for storage as well. Please try that again with 3.0.19. Thanks.
AdilMahboob 4 Posted October 15, 2018 Posted October 15, 2018 Please try that again with 3.0.19. Thanks. Will do. It hasn't appeared on my play store just yet.
AdilMahboob 4 Posted October 15, 2018 Posted October 15, 2018 (edited) Just got the update. No change, I still only have internal storage available. What's the criteria for it to display? Edit: I'm using a Samsung Galaxy S8 with 128gb external memory card installed. Edited October 15, 2018 by AdilMahboob 1
AdilMahboob 4 Posted October 17, 2018 Posted October 17, 2018 Whilst I wait for that update, I've reverted to version 2.9.90 and disabled auto-updated for Emby on the Play store. Seems to be stable for now.
