dougaddams 1 Posted July 13, 2018 Posted July 13, 2018 I have recently bought a certificate and wish to enable HTTPS, However I seem to be unable to enable it correctly, nomatter what my HTTP works,But I cannot get https to work correctly atall My settings are here below, followed by the error I get. Any suggestions?
darkassassin07 672 Posted July 13, 2018 Posted July 13, 2018 (edited) Your external domain name should not have 'https://' in front of it. Just start with www. Im actually surprised you arent having further problems. I just went to test my theory as I wasnt completely sure that was the problem. When I added the 'https://' saved and clicked restart. The server did not start again..? I then went to the server machine and tried to start emby but it still didnt load. I ended up editing <WanDdns> in system.xml and restarted my comp just for good measure. That solved it. @@Luke That may be some handy info for you Edited July 13, 2018 by darkassassin07
Solution Luke 42212 Posted July 13, 2018 Solution Posted July 13, 2018 External domain should just be the address only. No scheme or port. 1
