jonescrusher 1 Posted July 9, 2018 Posted July 9, 2018 (edited) I am having issues with playing alternate audio tracks when the video file contains TrueHD tracks. I know TrueHD will require transcoding but other tracks like commentary and alternate languages will generally Direct Play. If I select an alternate track that will direct play, it will not play the correct track. For example, if the video contains Track 1 – TrueHD Track 2 – Stereo Track 3 – Commentary 1 Track 4 – Commentary 2. If I select track 2, it will actually play Track 3. Select track 3 and it plays track 4. Select Track 4 and it plays Track 2. The attached log file shows this example where the server is correctly selecting track 2 and is allowing Direct Play. Other clients such as Web, Theater, and iPAD all correctly select the second stream but the Samsung client is off by one and selects the 3rd track. Testing with a video file with 2 TrueHD tracks shows it is off by 2. The Samsung client seems to be ignoring TrueHD tracks and counting based on allowed tracks which is not correct. I am still stuck running version 1.0.39 so am not sure if this issue has been resolved in a later version. server-63666672993.txt Edited July 9, 2018 by jonescrusher
Luke 42241 Posted July 9, 2018 Posted July 9, 2018 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
SamES 1084 Posted July 14, 2018 Posted July 14, 2018 Could I please get a copy of the media info for this file. Thanks
jonescrusher 1 Posted July 16, 2018 Author Posted July 16, 2018 Here is the media info from the Emby Web interface Media Info Video Title1080P H264 CodecH264 AVCYes ProfileHigh Level41 Resolution1920x1080 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.9760246 Bitrate29460 kbps Bit depth8 bit Pixel formatyuv420p Ref frames1 NAL4 Audio TitleEng TRUEHD 5.1 Languageeng CodecTRUEHD Layout5.1 Channels6 ch Sample rate48000 Hz Bit depth24 bit DefaultNo Audio TitleEng Dolby Digital 5.1 Default Languageeng CodecAC3 Layout5.1 Channels6 ch Bitrate640 kbps Sample rate48000 Hz DefaultYes Audio TitleEng Dolby Digital stereo Languageeng CodecAC3 Layoutstereo Channels2 ch Bitrate192 kbps Sample rate48000 Hz DefaultNo Audio TitleEng Dolby Digital stereo Languageeng CodecAC3 Layoutstereo Channels2 ch Bitrate192 kbps Sample rate48000 Hz DefaultNo Containermkv
IceBoosteR 10 Posted October 3, 2018 Posted October 3, 2018 I can confirm having this in my Samsung TV Emby app aswell. @@Luke this is fixed now in the latest version, just for confirmation?
Luke 42241 Posted October 3, 2018 Posted October 3, 2018 It depends on your model. Some have the update, but not all yet.
