wonderfulman1 1 Posted July 7, 2018 Posted July 7, 2018 (edited) Hello,HELP ME PLEASE!!!! I purchased the HDMI wifi EXCast4K dongle --> https://shopping.ezcast.com/prod/ezcast4k It works fine but has some problems because Emby server can transmit video files via DLNA protocol to the dongle, but it is not possible to control the time or volume. Using other types of software and transmitting the DLNA video stream to the dongle, time and volume control is possible.Could you verify and possibly solve the problem by reporting it to the programmers?I am available to perform all the tests you want to help you solve.Thank you Edited July 7, 2018 by wonderfulman1
Luke 42238 Posted July 7, 2018 Posted July 7, 2018 Can you please attach the emby server log from w when you tried this? You can learn how to do that here: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost Thanks.
wonderfulman1 1 Posted July 7, 2018 Author Posted July 7, 2018 (edited) HI, this is the screenshot this is the screenshot when I launch the movie and select the remote from the device icon at the top right of the browser Edited July 7, 2018 by wonderfulman1
wonderfulman1 1 Posted July 7, 2018 Author Posted July 7, 2018 (edited) excuse me but the site does not make me attach the file as an image ...... Edited July 7, 2018 by wonderfulman1
Luke 42238 Posted July 7, 2018 Posted July 7, 2018 I would suggest trying again with the next release as there have been some updates to this area. thanks.
wonderfulman1 1 Posted July 15, 2018 Author Posted July 15, 2018 when will the new version of emby server coming out?
wonderfulman1 1 Posted July 17, 2018 Author Posted July 17, 2018 (edited) Hello, I have just updated Emby server to the version 3.5.0 for windows, but the problem reported when opening this topic has not been solved by remaining the same as the previous version of the software. Could you check? If I can help you ask me for info. Thank you Edited July 17, 2018 by wonderfulman1
Luke 42238 Posted July 17, 2018 Posted July 17, 2018 Ok, i apologize. i did my best. I don't have one of these devices for testing. We'll have to look into getting one. Thanks.
wonderfulman1 1 Posted July 17, 2018 Author Posted July 17, 2018 (edited) No problem .. you did a very good job, and I'm really happy to use your software ... you're SUPER! If it can help you and I recommend it (I connected it to my projector to get a cinema effect). It is also compatible with H265 HEVC plays in 4K and and also MPH ... and the price is excellent when compared to the others (see Cromecast ULTRA) You could buy it here https://www.amazon.com/EZCast-Display-Wireless-Streaming-Decoding/dp/B07D73Q23Z/ref=sr_1_1_sspa?ie=UTF8&qid=1531852860&sr=8-1-spons&keywords=EZCast+4k&psc=1 Edited July 17, 2018 by wonderfulman1
wonderfulman1 1 Posted July 17, 2018 Author Posted July 17, 2018 I attach the new logfile there are these lines that may perhaps help you -2018-07-17 21:04:29.769 Info Dlna: No matching device profile found. The default will need to be used. -2018-07-17 21:09:33.497 Info HttpResultFactory: Setting range response values for \\MyVideo.avi. RangeRequest: bytes=105687350- Content-Length: 1400536508, Content-Range: bytes 105687350-1506223857/1506223858 2018-07-17 21:10:27.546 Info HttpServer: HTTP Response 500 to 192.168.1.104. Time: 54059ms (slow). http://192.168.1.102...naheaders=true 2018-07-17 21:12:35.603 Error Dlna: Error reporting playback stopped EmbyLOG v.3.5.0.txt
wonderfulman1 1 Posted July 30, 2018 Author Posted July 30, 2018 (edited) Hi, are there any news? Edited July 30, 2018 by wonderfulman1
Luke 42238 Posted July 30, 2018 Posted July 30, 2018 Please try emby server 3.5.2, but I have not tested ezcast yet myself. Thanks.
wonderfulman1 1 Posted July 31, 2018 Author Posted July 31, 2018 (edited) Does emby server work with amazon fire stick? Edited July 31, 2018 by wonderfulman1
wonderfulman1 1 Posted August 2, 2018 Author Posted August 2, 2018 (edited) Emby APP for Amazon stick Is the application free or paid?if paid, pay only once or do you have to pay a subscription?thank you Edited August 2, 2018 by wonderfulman1
wonderfulman1 1 Posted August 12, 2018 Author Posted August 12, 2018 I asked for the return to Amazon, and bought the amazon fire tv stick ... much better!
