Pirlo1966 22 Posted April 1, 2014 Posted April 1, 2014 Latest beta server & Clasic. Classic config xml has the sort replace word tag filled in. However, It doesn't seem to skip the sort replace words while sorting movies...? Is this functionality obsolete?
ebr 16334 Posted April 1, 2014 Posted April 1, 2014 Yes, that is obsolete on the client side as that value was used to create the Sort Name and that is now done on the server side.
Pirlo1966 22 Posted April 1, 2014 Author Posted April 1, 2014 Thanks for clarifying. Any plans to remove that tag and other obsolete tags?
Pirlo1966 22 Posted April 1, 2014 Author Posted April 1, 2014 (edited) Have been looking into server config xml. The tags below are present but it doesn't seem to work in MB Classic? <SortReplaceCharacters> <string>.</string> <string>+</string> <string>%</string> </SortReplaceCharacters> <SortRemoveCharacters> <string>,</string> <string>&</string> <string>-</string> <string>{</string> <string>}</string> <string>'</string> <string>[</string> <string>]</string> <string>(</string> <string>)</string> </SortRemoveCharacters> <SortRemoveWords> <string>the</string> <string>a</string> <string>an</string> <string>de</string> <string>het</string> <string>een</string> <string>le</string> <string>la</string> <string>les</string> </SortRemoveWords> Edited April 1, 2014 by ehgeahrev
ebr 16334 Posted April 1, 2014 Posted April 1, 2014 Thanks for clarifying. Any plans to remove that tag and other obsolete tags? Not necessarily. Removing some of these things could break components that may still reference them so I am very careful about removing stuff. It isn't hurting anything.
Pirlo1966 22 Posted April 1, 2014 Author Posted April 1, 2014 It isn't hurting anything. Except stupid people like me filling in these tags for 4 users on 3 different HTPC's
ebr 16334 Posted April 1, 2014 Posted April 1, 2014 We've pretty much gone away from needing to do any manual editing of the config files. If it isn't exposed in the config interface, don't worry about it.
