nanuk 36 Posted December 24, 2018 Author Posted December 24, 2018 (edited) With 4K Remux MPEG-H HEVC 2160p 10bit HDR10 / True HD/Atmos 7.1 24bit, it will pause/stutter on playback every few minutes and the only way I have found to smooth it out is turn subs off completely, switch to 5.1 dolby digital audio track then back to the True HD track then it seems to play for 30 minutes or so before happening again. CPU/Mem/DIsk for media server at these points are hardly being touched so its not Disc I/O or CPU maxing out. When I playback in browser with emby over HDMI to TV the colour is washed out. Same with Kodi.... so would be really like to get the LG app sorted. Hi VellaiT, I have the exact same problem and the reasons are now clear and the emby app is NOT responsible for the problem :-/ When I play a 4K Remux MPEG-H HEVC 2160p 10bit HDR10 / True HD/Atmos file (and True HD/Atmos is really the only format the playback is stuttering) I looked on the device manager of my Windows Server and determined that the HDD that emby uses to transcode is at 100% after a few minutes/seconds and that's exactly when the playback begins to stutter! Even when I use a SSD to put my temporary transcoding path on, the problerm still exists... BUT the stuttering gets better... that's an indicator that the reason really is the speed of the HDD. because the system is writing to the harddsik with full speed and is trying the read from the same disc at the same time... I think if there woukd be a possibility to prioritize the read and write tasks of the system, that would solve the prob, but actually I found no way to do this. True HD/Atmos is the only audio format that has to by transcoded by emby because the LG TV seems not to be able to play that naturally. ->When I playback in browser with emby over HDMI to TV the colour is washed out. Same with Kodi.... The reason for this is that your playback device you are running kodi on is not able to send the HDR information to your TV, maybe the graphics card is not HDMI 2.0 compatible or samething like that. Kodi 17.x is not able to do a HDR to SDR conversion so that the colours are looking terrible and as you described "washed out". The upcoming Kodi 18 is able to do a HDR to SDR conversion maybe you can try this one ;-) there is already a RC3 out and I think the final version will be there in a view days. Edited December 24, 2018 by nanuk
VellaiT 0 Posted December 24, 2018 Posted December 24, 2018 Hi, Thanks for taking the time to respond. The first thing I was thinking was CPU or Disk I/O aswell, but I have watched this carefully and emby doesn't use even 20% of the bandwidth for disk even when the pause/stutter happens. I have dual 800Gb Intel DC S3520 cache on both read and write to 7200rpm 8 drive WD Gold array. This system can easily serve 10+ simultaneous users editing 4k raw video files...so it should be able to handle 1x 4k compressed stream. I had a feeling it was a HDR issue with the colours on HDMI direct output, I have confirmed the board definitely supports HDMI 2.0 so will have to work on driver tweaks until I get it working correctly.... I will also check out Kodi beta again as well... its been a while as I made the switch to emby premiere around 6 months ago and have been working through some network upgrades and server upgrade etc. In regards to the audio - I understand the LG cannot decode the True HD natively from other posts, but I am passing through to a NAD M17 V2 Processor with ARC and not using the LG... do you think this would still present the same issue? Seems odd that if I switch stream after movie starts then back again, the audio is fine from then on.
nanuk 36 Posted December 24, 2018 Author Posted December 24, 2018 I have dual 800Gb Intel DC S3520 cache on both read and write to 7200rpm 8 drive WD Gold array. This system can easily serve 10+ simultaneous users editing 4k raw video files...so it should be able to handle 1x 4k compressed stream. Of course it should be able to handle 1x 4k compressed stream... the problem is that emby writes to the disc with full speed, that means in case of a 4K movie (50-70GB) it is not transcoding in real time but it transcodes / writes much faster to your HDD than it reads. to show you I startet a 4K movie with TruaHD on my LG TV and made a screenshot of my hardware manager after about 3 minutes, when the stuttering started for the first time. At this time emby/ffmpeg is writing with 140 MB/s to the harddisk and is trying to read at the same time... and thats not working well :-) This also explains why the 4K movies are only stuttering when you use the Atmos/TrueHD audio and all others (DD5.1/DTS MA/DTS:X...) are working well and without stuttering!
Luke 42237 Posted December 24, 2018 Posted December 24, 2018 So the TV is outputting to the receiver via HDMI, is that correct?
nanuk 36 Posted December 24, 2018 Author Posted December 24, 2018 So the TV is outputting to the receiver via HDMI, is that correct? In my case yes...
nanuk 36 Posted December 24, 2018 Author Posted December 24, 2018 (edited) The first thing I was thinking was CPU or Disk I/O aswell, but I have watched this carefully and emby doesn't use even 20% of the bandwidth for disk even when the pause/stutter happens. a good way to test if it's really not your HDD is to just let the movie play for lets say 10 minutes (ignore the stuttering) and I bet after about 10 minutes (depending on the transcoding speed of your system) after the transcoding is completly done the playback will run smooth ;-) and do not rewind or fastforward because this will force emby to do an new transcoding process ;-/ Edited December 24, 2018 by nanuk
VellaiT 0 Posted December 24, 2018 Posted December 24, 2018 Hi Luke - yes its HDMI ARC back to the processor. Nanuk - I will do some more testing, but if this is really the issue then emby need to address it, this is top tier hardware short of going full NVME storage which is unrealistic for 99% of home users. I was having this same issue previously with a synology DS1817+, but that was CPU maxing out as its a quad core atom so not surprising... It wasn't showing disk I/O anywhere near max either as I have dual SSD cache on that also that far exceed the size of the file being processed. Might have to keep on going with HDMI 2.0 issue and if I get that resolved look at switching back to Kodi.
nanuk 36 Posted December 24, 2018 Author Posted December 24, 2018 Nanuk - I will do some more testing, but if this is really the issue then emby need to address it, this is top tier hardware short of going full NVME storage which is unrealistic for 99% of home users. Yes, I totally agree... and please do the testing and let me know about your result... this problem bores me for months :-/
VellaiT 0 Posted December 25, 2018 Posted December 25, 2018 (edited) So I have spent the day on it today....really makes no sense to me... CPU hitting 84% max and disk hardly being touched. Constant stalling and stuttering on playback to a point where I am going to another source as its unwatchable. I have tried intel hardware acceleration on, off, prioritise emby and ffmpeg to high and real-time... no other services running that can use major resources. No amount of pause and wait for it catch up works either, letting it run for 15-20mins makes no difference. Really starting to Pi$$ me off. Screenshots from 3 different points, but it's all pretty much the same. Edited December 25, 2018 by VellaiT
Luke 42237 Posted December 25, 2018 Posted December 25, 2018 Hi, try using the quality setting in the video player to lower the quality to a value that your network can handle. Thanks.
nanuk 36 Posted December 25, 2018 Author Posted December 25, 2018 @@VellaiT what Luke said is another very interessting point... All LG TVs only have 100mbit networkinterfaces build in :-/ that's in case of a 4K remux sometimes a bottleneck :-) sad but true... I use a wireless network connection because it's faster :-)))
VellaiT 0 Posted December 25, 2018 Posted December 25, 2018 Hi Guys, Yes I had read that before somewhere else and already have it set to 4k 100mb.... no difference in performance. I will try the wifi like you suggest aswell and see if that has any bearing on this...
VellaiT 0 Posted December 26, 2018 Posted December 26, 2018 No such luck with the wifi either, tried 4k/80, 4k/100, 4k/120 and just as bad with all of them on wifi or ethernet. The server is barely being touched CPU/Mem/Storage/GPU so looking like this is just not going to work. Back to Kodi and getting HDMI 2.0/HDR sorted. Let me know how you go when Server 3.6 out and ill retest then... failing that its time to cancel the premiere subscription and get a refund.
Luke 42237 Posted December 27, 2018 Posted December 27, 2018 I would try lowering the quality setting even further.
VellaiT 0 Posted December 28, 2018 Posted December 28, 2018 Yeah na.... that's not a solution... to get it to play smoothly its back to 1080p which defeats the entire purpoise of having this kind of kit and source material. I have kodi running properly now and HDR working so how do I get a refund to my annual emby subscription?
dirkdigs 10 Posted March 9, 2019 Posted March 9, 2019 i have same issue. change audio from TRUEHD 7.1 to DOLBY 5.1 and it works fine.
Luke 42237 Posted July 25, 2019 Posted July 25, 2019 Emby for LG 1.0.16 has been released. Stay tuned to our blog for the announcement. Thanks.
Luke 42237 Posted August 19, 2019 Posted August 19, 2019 Emby for LG 1.0.18 has been released. Stay tuned to our blog for the announcement. Thanks.
Luke 42237 Posted October 25, 2019 Posted October 25, 2019 Emby for LG 1.0.19 has been released. Stay tuned for the release announcement on our blog.
Luke 42237 Posted November 19, 2019 Posted November 19, 2019 Emby for LG 1.0.20 has been released. Stay tuned for the release announcement on our blog.
ChefChaudard 2 Posted March 11, 2021 Posted March 11, 2021 (edited) 2021, and still stuttering for many 4k movies ... impossible to watch them. My Synology works as hell when I try. Luckily, native LG video reader can play them. Edited March 11, 2021 by ChefChaudard
rbjtech 5341 Posted March 12, 2021 Posted March 12, 2021 The only real bottleneck on the TV's is the 100Mbit Ethernet interface - so if you have any high bitrate 4K files over 85-90 Mbit/sec then you will simply hit the Ethernet limit. There are simply ways around this using USB to Gig Ethernet adapters - there are some threads in the LG section if you do a search. If you are trying to play HD Audio on your TV, then it will transcode - so simply select the non HD Audio track before you press play. My suggestion if you have no method to play HD Audio is to either set the default to be the non-HD track, or simply remove the track(s) (but you may need it 'one day', so personally I would leave it, unless you need the disk space..)
