Mopar_Mudder 14 Posted July 5, 2018 Posted July 5, 2018 I have a TV Series that is showing the wrong episode for Next Up, is their a way to reset that?
Luke 42211 Posted July 5, 2018 Posted July 5, 2018 Can you please go over some specifics of an example and discuss why you feel that it is wrong? Thanks !
Mopar_Mudder 14 Posted July 5, 2018 Author Posted July 5, 2018 I have a series that the first unwathced episode is season 4 episode 21. The next up shows season 3 episode 9, which is checked as watch. Did a refresh and it didn't fix it.
Happy2Play 9802 Posted July 5, 2018 Posted July 5, 2018 (edited) I have a series that the first unwathced episode is season 4 episode 21. The next up shows season 3 episode 9, which is checked as watch. Did a refresh and it didn't fix it. Does it have a "Sort title"? They cause this issue. Edited July 5, 2018 by Happy2Play
Luke 42211 Posted July 5, 2018 Posted July 5, 2018 Check the sort title for all episodes in the series. Does any episode have a sort title?
Mopar_Mudder 14 Posted July 6, 2018 Author Posted July 6, 2018 Check the sort title for all episodes in the series. Does any episode have a sort title? No they don't
Solution Mopar_Mudder 14 Posted July 6, 2018 Author Solution Posted July 6, 2018 Ok I found a couple of episodes that the scraper put in completely wrong seasons and episodes because they had numbers in the title. fixed them and all seems good now. 1
