Oracle 86 Posted July 4, 2018 Posted July 4, 2018 This is not, by any means, an urgent issue. I am just looking to clean up my TV file system & am curious as to what the best method is to do this. By "clean up", I mean sort the shows via category or genre, while keeping them separate on my actual Emby server. My level of intelligence in this sort of thing isn't 100%, but I do have some knowledge in how to make all this stuff flow together & work. Any help would be appreciated. My TV File System (Partial) - https://gyazo.com/f08862f080615c9487c37d28d9377bf1 My Movie File System (Essentially what I want, if possible) - https://gyazo.com/fd5e752a77622e25fdab78732a05a920
Oracle 86 Posted July 4, 2018 Author Posted July 4, 2018 Background on my server set-up: Using old desktop & two external 4TB drives. I'm looking to optimize the loading time in my file system with this project.
Solution ebr 16310 Posted July 4, 2018 Solution Posted July 4, 2018 If you really don't want to affect the presentation in Emby then I suggest adding each new "organizational" folder to the respective library as a location. e.g. If you have: TV Shows/Comedy /Drama Then, when you create the library, add "TV Shows/Comedy" and "TV Shows/Drama" both as locations for your TV library instead of just "TV Shows". 2
Oracle 86 Posted July 4, 2018 Author Posted July 4, 2018 That might work. Let me play around with that idea at some point today (I have a bunch of content to transfer to my server from a seperate PC) and I'll let you know. Thanks.
Oracle 86 Posted July 4, 2018 Author Posted July 4, 2018 That worked out perfect! Thanks! If you really don't want to affect the presentation in Emby then I suggest adding each new "organizational" folder to the respective library as a location. e.g. If you have: TV Shows/Comedy /Drama Then, when you create the library, add "TV Shows/Comedy" and "TV Shows/Drama" both as locations for your TV library instead of just "TV Shows". 1
