theGeek 4 Posted March 31, 2014 Posted March 31, 2014 Some of my movies have sync issues during playback. The problem isn't hardware related because they are out of sync on all my devices and playback software. So it happened during ripping. When I was using XBMC there was an Audio Delay adjustment that I could do to fix this for my videos. Is there any way to do this with Media Browser?
Deihmos 170 Posted March 31, 2014 Posted March 31, 2014 It depends on the codec you are using. Lav has an audio delay adjustment and you can do the same with ffdshow.
theGeek 4 Posted April 1, 2014 Author Posted April 1, 2014 so there's no way to do it within MB or on the fly?
ebr 16334 Posted April 1, 2014 Posted April 1, 2014 so there's no way to do it within MB or on the fly? MBC doesn't handle playback, we just hand it off to WMC or your external player so it has to be taken care of by the codecs involved. Are you the same "theGeek" from AVS? Does this mean your theater is done...?
Deihmos 170 Posted April 1, 2014 Posted April 1, 2014 (edited) If you are using lav for audio you will have to open the config to adjust it. If you are using ffdshow like i do you can adjust it using the remote by installing media control. Edited April 1, 2014 by Deihmos
