z3ndra 7 Posted July 1, 2018 Posted July 1, 2018 Hello I have a problem, my remote connection link (wan) does not work, I fall on a page 178.167 ..... does not allow the connection. yet the firewall of the server let well ports 80 and 443 as I set in emby. I do not understand why it does not work. while the local link works perfectly, even when I'm not on the same network. Do you have an idea ? because that must be why my domain name does not work with the server. thank you in advance
Luke 42242 Posted July 1, 2018 Posted July 1, 2018 Remote control uses the web socket protocol so you'll need to make sure that is allowed through your server.
ebr 16335 Posted July 1, 2018 Posted July 1, 2018 Hi. Are you talking about logging in to your server remotely or using the remote playback capability from one app to another?
