vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 The display height and width on that sample have no values. Fill them both in, and try again. The whole frame needs to be filled, not just the height, Yes, I've done that, but it not triggers. My system doesn't support DTS 7.1 Maybe this is the cause?
Guest asrequested Posted January 1, 2019 Posted January 1, 2019 Yes, I've done that, but it not triggers. My system doesn't support DTS 7.1 Maybe this is the cause? Is it remuxing?
CBers 7554 Posted January 1, 2019 Posted January 1, 2019 So all of your videos play HDR when stretched? For samples that I could get to trigger HDR, the video was stretched.
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 Is it remuxing? Yes, so this is the cause. I loose HDR in the remux process. But Plex, doesn't remux the video, so using Plex I have HDR.
Guest asrequested Posted January 1, 2019 Posted January 1, 2019 Yes, so this is the cause. I loose HDR in the remux process. But Plex, doesn't remux the video, so using Plex I have HDR. If the video is being copied, it shouldn't affect it. Unless those values are being changed in the remux??? That isn't something I can work around. That's all ffmpeg.
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 If the video is being copied, it shouldn't affect it. Unless those values are being changed in the remux??? That isn't something I can work around. That's all ffmpeg. According to the log file audio is converted from DTS to AC3. For me, this is not a remux, is transcoding. But Emby labels it as remux. I consider remux just copy to another container.
Guest asrequested Posted January 1, 2019 Posted January 1, 2019 According to the log file audio is converted from DTS to AC3. For me, this is not a remux, is transcoding. But Emby labels it as remux. I consider remux just copy to another container. But the video is copied, correct? And any change made, the file gets remuxed.
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 But the video is copied, correct? And any change made, the file gets remuxed. Yes, video copied and audio transcoded. I thought remux refers to copying audio and video to another container, if any of the streams is changed, then we talk about transcoding. This is what has confused me, I have seen a remuxing log and I have thought that neither the video nor the audio stream were modified.
CBers 7554 Posted January 1, 2019 Posted January 1, 2019 No, in Emby-land, audio is "remuxed", video is transcoded. Both the same really. 1
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 Another question could be, why does plex play directly the sample and instead emby needs remux? Maybe it's related to a modified version of the player they (Plex) use.
CBers 7554 Posted January 1, 2019 Posted January 1, 2019 If you set up and external player, such as the Archos Media Player, then it will trigger HDR, untouched. Well, it does here, but then my soundbar supports DTS etc. You could convert the audio to DD, which should stop the remuxing. 2
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 If you set up and external player, such as the Archos Media Player, then it will trigger HDR, untouched. Well, it does here, but then my soundbar supports DTS etc. You could convert the audio to DD, which should stop the remuxing. I have many movies with DTS 5.1 and they do not cause me problems, I think the problem is with the DTS 7.1 Your sample is the first one I have in 7.1. If I ever find any DTS 7.1 I already know what I have to do. Thank you! 1
CBers 7554 Posted January 2, 2019 Posted January 2, 2019 And I asked for a sample. @ - you saw the sample I posted earlier, didn't you? If so, did you have any luck with it?
Guest asrequested Posted January 2, 2019 Posted January 2, 2019 @ - you saw the sample I posted earlier, didn't you? If so, did you have any luck with it? Yeah, I posted that when stretched, it plays the the HDR, but obviously it doesn't if unmodified.
CBers 7554 Posted January 2, 2019 Posted January 2, 2019 Yeah, I posted that when stretched, it plays the the HDR, but obviously it doesn't if unmodified. So no workaround then?
vdatanet 1619 Posted January 2, 2019 Posted January 2, 2019 So no workaround then? Doofus from the first moment said that the film was stretched, I think his intention was to show that it was a problem of the size of the visualization and not of the encoding, his intention was not to give a workaround.
Guest asrequested Posted January 2, 2019 Posted January 2, 2019 (edited) So no workaround then? No. I suspect what is happening is the decoder just isn't adding padding, and ExoPlayer is relying on that. This is all Dev stuff. Beyond my skill set. There's probably some handle jiggling that could be done in the app, but I think ebr is preferring a more solid fix. Edited January 2, 2019 by Doofus 1
vdatanet 1619 Posted January 9, 2019 Posted January 9, 2019 With version 7.2.2 the same thing happens
Guest asrequested Posted January 9, 2019 Posted January 9, 2019 I imagine ExoPlayer will have to make a few tweaks, too.
solidus28 12 Posted January 9, 2019 Posted January 9, 2019 (edited) You guys are awesome. I've been fighting this since early 2018 and could never figure out why some things didn't trigger HDR. Hopefully Exoplayer gets updated to handle it. I didn't initially read a few posts up and discovered for myself that the video can be VERY stretched if it was super wide to begin with I'll keep an eye on this thread. Edited January 9, 2019 by solidus28
Jdiesel 1439 Posted January 9, 2019 Posted January 9, 2019 (edited) Anyone have an example file of a cropped video that won't trigger? I was thinking of trying to reencode while adding padding to see if it works. I think this is the string I would use to adding padding to a 3840x1600 resolution cropped video ffmpeg -i input.mkv -vf "pad=width=3840:height=2160:x=0:y=280:color=black" output.mkv Edited January 9, 2019 by Jdiesel
CBers 7554 Posted January 9, 2019 Posted January 9, 2019 Anyone have an example file of a cropped video that won't trigger? I was thinking of trying to reencode while adding padding to see if it works. I think this is the string I would use to adding padding to a 3840x1600 resolution cropped video ffmpeg -i input.mkv -vf "pad=width=3840:height=2160:x=0:y=280:color=black" output.mkv https://emby.media/community/index.php?/topic/60362-shield-atv-hdr/page-2&do=findComment&comment=647336
Guest asrequested Posted January 9, 2019 Posted January 9, 2019 Anyone have an example file of a cropped video that won't trigger? I was thinking of trying to reencode while adding padding to see if it works. I think this is the string I would use to adding padding to a 3840x1600 resolution cropped video ffmpeg -i input.mkv -vf "pad=width=3840:height=2160:x=0:y=280:color=black" output.mkv I have movies with padding, that work.
Guest asrequested Posted January 10, 2019 Posted January 10, 2019 (edited) Android needs to think it's full frame, or the ability to use HDR passthrough is disabled. If you look at every 4k HDR remux/rip, every one of them is full frame. Some with padding, some without. That's all that the cropping is... removing the padding. So Android and Windows are both expecting full frame video. The decoders should have the ability to render padding where needed, during decoding. Given the issues that cuda has with parsing some HDR content (no idea if that's related), it's not surprising something like this might happen. Yay for tone mapping Edited January 10, 2019 by Doofus
