CBers 7554 Posted December 31, 2018 Posted December 31, 2018 @ Which values did you change in the file header, as @@FrostByte and I have been amending both the "Video Pixel Height" and "Video Display Height" to 2160, but HDR still doesn't trigger ? You change the display height not the video. I'll post a screenshot in a little while. "Video Display Height" ? 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 Here you go, guys. No need to run a library scan after you save the change. Doing this has nothing to do with Emby. 3
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 Here you go, guys. No need to run a library scan after you save the change. Doing this has nothing to do with Emby. Yep, that's what I did earlier, but it made no difference, HDR wasn't triggered in Emby. 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 Yep, that's what I did earlier, but it made no difference, HDR wasn't triggered in Emby. Works everytime, for me
vdatanet 1619 Posted December 31, 2018 Posted December 31, 2018 For me it also works, if I set Video Display Height to 2160 it triggers HDR. 1
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 Yep, that's what I did earlier, but it made no difference, HDR wasn't triggered in Emby. Works everytime, for me For me it also works, if I set Video Display Height to 2160 it triggers HDR. OK, I'll try again in a while. You didn't need to do anything in Emby? 1
vdatanet 1619 Posted December 31, 2018 Posted December 31, 2018 OK, I'll try again in a while. You didn't need to do anything in Emby? No, I changed the value and I played start the movie. 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 You just save the change, and play the video. No need to scan or restart anything emby. 1
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 OK, so changing just the Video Display Height to 2160 triggers HDR now !! 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 So that's the issue. Android has to run at full screen for it to activate HDR (same as Windows). It looks like Exoplayer/shield is circumventing that by setting frame size according to the video frame. I would imagine that the other apps like plex are probably making sure that Android maintains full screen, regardless of video frame ratio. 1
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 I wonder if somehow Plex is setting the "Video Display Height" value to 2160 before playback starts. I wonder if @@ebr can do something similar. 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 I wonder if somehow Plex is setting the "Video Display Height" value to 2160 before playback starts. I wonder if @@ebr can do something similar. If you were to correct this by changing that, you'd have to add padding, so that Android sees information in those last 5 pixels. Or it would just stretch the image.
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 I have changed the "Video Display Height" value to 2160 on a few other samples/movies I have, but they are not triggering HDR. 1
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 For 2 samples that do trigger HDR, are in fact stretched. 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 I have changed the "Video Display Height" value to 2160 on a few other samples/movies I have, but they are not triggering HDR. Can you share one? Or link me to it?
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 Can you share one? Or link me to it? I'll do it tomorrow, as getting ready for New Year now, plus I've had enough of it today 2
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 In my testing, if it triggers HDR video is stretched. If HDR is not triggered video is not stretched. (1) triggers hdr.txt -> After setting VDH to 2160 triggers HDR but video is stretched (2) not triggers hdr.txt -> After setting VDH to 2160 not triggers HDR and video is not strecched File (2) is supposed to be HDR, but I think it's not and obviously doesn't trigger HDR, and plex doesn't too. triggers hdr.txt not triggers hdr.txt 1
CBers 7554 Posted January 1, 2019 Posted January 1, 2019 Can you share one? Or link me to it? Here is a link to a 30 second sample. The Media Info for the sample is: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 32 s 366 ms Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Writing library : x265 2.7+17-2e370d98c806:[Windows][GCC 6.3.0][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=156295 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / max-cll=1000,295 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Statistics Tags Issue : no_variable_data 1970-01-01 00:00:00 / Lavf58.18.102 FromStats_BitRate : 28349751 FromStats_Duration : 00:00:30.135000000 FromStats_FrameCount : 156295 FromStats_StreamSize : 23100809584 Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 295 cd/m2 I haven't changed the VDH on this sample. It does not trigger HDR in the Emby ATV app, but it does in the Plex ATV app and Archos Media Player if used as an external player to Emby ATV app. 1
Guest asrequested Posted January 1, 2019 Posted January 1, 2019 Here is a link to a 30 second sample. The Media Info for the sample is: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 32 s 366 ms Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Writing library : x265 2.7+17-2e370d98c806:[Windows][GCC 6.3.0][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=156295 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / max-cll=1000,295 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Statistics Tags Issue : no_variable_data 1970-01-01 00:00:00 / Lavf58.18.102 FromStats_BitRate : 28349751 FromStats_Duration : 00:00:30.135000000 FromStats_FrameCount : 156295 FromStats_StreamSize : 23100809584 Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 295 cd/m2 I haven't changed the VDH on this sample. It does not trigger HDR in the Emby ATV app, but it does in the Plex ATV app and Archos Media Player if used as an external player to Emby ATV app. When I change the height, it stretches and enables HDR, for me
CBers 7554 Posted January 1, 2019 Posted January 1, 2019 When I change the height, it stretches and enables HDR, for me Yes, if you change the height, it stretches the video, so not a solution. Still triggers HDR in Plex, even untouched. 1
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 When I change the height, it stretches and enables HDR, for me This not triggers HDR for me.
CBers 7554 Posted January 1, 2019 Posted January 1, 2019 This not triggers HDR for me. Did you change the VDH value in the header? It won't trigger HDR as is, unless you play it in Plex. 1
Guest asrequested Posted January 1, 2019 Posted January 1, 2019 Yes, if you change the height, it stretches the video, so not a solution. Still triggers HDR in Plex, even untouched. I'm confused. You said; I have changed the "Video Display Height" value to 2160 on a few other samples/movies I have, but they are not triggering HDR. And I asked for a sample. So all of your videos play HDR when stretched?
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 I think that Doofus does not propose this as a solution rather as a demonstration that the problem is in the crop and not in the encoding.
Guest asrequested Posted January 1, 2019 Posted January 1, 2019 This not triggers HDR for me. The display height and width on that sample have no values. Fill them both in, and try again. The whole frame needs to be filled, not just the height,
