ebr 16338 Posted December 19, 2018 Posted December 19, 2018 They don't know. They are consulting with Nvidia.
Guest asrequested Posted December 19, 2018 Posted December 19, 2018 (edited) Well that's progress, at least. I'm assuming they're able to reproduce the issue? Edited December 19, 2018 by Doofus
CBers 7554 Posted December 25, 2018 Posted December 25, 2018 As a work-around, could we add a TAG to the "cropped" content and have the ATV app open it in an external player that will trigger HDR please? Can this be considered please? 1
CBers 7554 Posted December 30, 2018 Posted December 30, 2018 OK, so I have a 1920x1080 UHD movie that triggers HDR on my TV. Title 1080p HEVC Codec HEVC Profile Main 10 Level 150 Resolution 1920x1080 Aspect ratio 16:9 Anamorphic No Interlaced No Framerate 23.976 Bitrate 8,174 kbps Video range HDR Colour primaries bt2020 Colour space bt2020nc Colour transfer smpte2084 Pixel format yuv420p10le Ref frames 1 1
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 OK, so I have a 1920x1080 UHD movie that triggers HDR on my TV. Title 1080p HEVC Codec HEVC Profile Main 10 Level 150 Resolution 1920x1080 Aspect ratio 16:9 Anamorphic No Interlaced No Framerate 23.976 Bitrate 8,174 kbps Video range HDR Colour primaries bt2020 Colour space bt2020nc Colour transfer smpte2084 Pixel format yuv420p10le Ref frames 1 The ratio is unchanged and likely hasn't be re-encoded. I have a bunch of these, too. Netflix stuff.
CBers 7554 Posted December 30, 2018 Posted December 30, 2018 The ratio is unchanged and likely hasn't be re-encoded. I have a bunch of these, too. Netflix stuff. Which still points to cropped videos being the issue. 1
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 Which still points to cropped videos being the issue. Oh that's what you were conveying. I misinterpreted
FrostByte 5454 Posted December 30, 2018 Posted December 30, 2018 That info for the 1080p movie he posted earlier is from a reencoded x265. He just didn't post the entire mediainfo Title : x265 / 6602 kbps / 1080p / 23.976 fps / 16:9 / Main 10 Profile 5.0 High / 4:2:0 / 10 bits / HDR / BT.2020 Writing library : x265 2.9+8-27d8424c799d:[Windows][GCC 8.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=127158 / level-idc=50 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=16 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=4 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=2 / limit-modes / me=3 / subme=7 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=1.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / bitrate=66
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 I've just looking at details several of my 4k HDR stuff. The change in aspect ratio is definitely a common factor, but I think I may have spotted another commonality. I was comparing x265 writing libraries. The ones that have the issue, also use x265 2.5, while the uncropped use x265 2.6. I wonder if that combination is what makes the difference? Cropped Writing library : x265 2.5+58-06979c042350:[Windows][GCC 6.2.1][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=217718 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,0) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 Full frame Writing library : x265 2.6+22-ff02513b92c0:[Windows][GCC 6.3.0][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=243218 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50) / max-cll=1242,436 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-save=(null) / analysis-load=(null) / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 I haven't gone through all of them, but can anyone else confirm this?
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 That info for the 1080p movie he posted earlier is from a reencoded x265. He just didn't post the entire mediainfo Title : x265 / 6602 kbps / 1080p / 23.976 fps / 16:9 / Main 10 Profile 5.0 High / 4:2:0 / 10 bits / HDR / BT.2020 Writing library : x265 2.9+8-27d8424c799d:[Windows][GCC 8.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=127158 / level-idc=50 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=16 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=4 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=2 / limit-modes / me=3 / subme=7 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=1.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / bitrate=66 And look at that. An even later writing library, 2.9. I wonder if 2.5 is the issue?
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 Ah I just found one with 2.6 that also didn't work. So there goes that theory. 1
vdatanet 1619 Posted December 30, 2018 Posted December 30, 2018 Ah I just found one with 2.6 that also didn't work. So there goes that theory. I have a lot of movies with this writing library: Writing library : x265 2.9+16-1f44f1f1623d:[Linux][GCC 8.2.0][64 bit] 10bit none of them fires hdr. All are cropped.
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 (edited) Ok, it's solely the video height. I just edited the file header to say that the display height was 2160 and not 1608. So the picture gets stretched and fills the whole frame. It played with HDR. That's pretty conclusive, I would say. Edited December 30, 2018 by Doofus 2
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 And the threshold appears to be 2155. Below that, and no HDR 3
FrostByte 5454 Posted December 30, 2018 Posted December 30, 2018 Okay after further testing 2160p Remux triggers HDR any 2160p x265 reencode full screen triggers HDR The.Dark.Knight.2008.2160p.UHD.BluRay.X265-IAMABLE 2160p x265 reencode cropped doesn't trigger HDR The.Matrix.Reloaded.2003.2160p.UHD.BluRay.X265-IAMABLE 1080p remux triggers HDR any 1080p x265 reencode full screen triggers HDR The.Lion.King.1994.1080p.UHD.BluRay.DDP.7.1.HDR.x265.D-Z0N3 1080p x265 reencode cropped doesn't trigger HDR Avengers.Age.of.Ultron.2015.1080p.UHD.BluRay.DD5.1.HDR.x265-DON 2
FrostByte 5454 Posted December 30, 2018 Posted December 30, 2018 And the threshold appears to be 2155. Below that, and no HDR Nice catch, I don't have anything with just a little crop like that
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 Nice catch, I don't have anything with just a little crop like that You can change the header with mkvtoolnix. Just remember what the original height, was 1
FrostByte 5454 Posted December 30, 2018 Posted December 30, 2018 Okay, then the reverse should be true. If you change the header of a cropped 4K movie to 2160p it should trigger HDR.
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 Okay, then the reverse should be true. If you change the header of a cropped 4K movie to 2160p it should trigger HDR. That was what I did. You stretch the cropped video to full frame, and it works. But I think you might mean if you squash a full frame, down, then you get no HDR? This time, if you lower the video height and leave the display height unchanged, no HDR. 1
FrostByte 5454 Posted December 30, 2018 Posted December 30, 2018 (edited) Fantastic. Ya, I had that reversed. So, if this is the case then maybe @ebr / @Luke can make an easy change to the client or server to fool it to think it hasn't been cropped. Otherwise, I think it may be a very long time before it gets fixed. We've been waiting for a year for MS to fix HDR on the Xbox now. Edit: as long as it doesn't look stretched that is when doing so Edited December 30, 2018 by FrostByte
CBers 7554 Posted December 30, 2018 Posted December 30, 2018 Stretched HDR would look worse than no HDR 1
Guest asrequested Posted December 30, 2018 Posted December 30, 2018 (edited) Stretched HDR would look worse than no HDR lol Fantastic. Ya, I had that reversed. So, if this is the case then maybe @ebr / @Luke can make an easy change to the client or server to fool it to think it hasn't been cropped. Otherwise, I think it may be a very long time before it gets fixed. We've been waiting for a year for MS to fix HDR on the Xbox now. Edit: as long as it doesn't look stretched that is when doing so I thought about that, but I'm not sure how that would work. This is handled specifically by the player. You'd have to get the splitter/decoder to read the center of the frame and not the outer edges, as it appears to take it's info from those last 5 pixels. Edited December 30, 2018 by Doofus
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 Thinking about this a little, HDR enabling only works at full screen. This is how it's been with Windows, too. So it might appear as though shield is relying on the decoder info to specify the video ratio, when it should just respect Android is setting everything as full screen.
CBers 7554 Posted December 31, 2018 Posted December 31, 2018 @ Which values did you change in the file header, as @@FrostByte and I have been amending both the "Video Pixel Height" and "Video Display Height" to 2160, but HDR still doesn't trigger ? Media Info of the sample file we've been testing on: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 10 s 594 ms Bit rate : 8 747 kb/s Width : 3 840 pixels Height : 2 160 pixels Original height : 1 600 pixels Display aspect ratio : 16:9 Original display aspect ratio : 2.40:1 Strangely, all of the samples I have that don't trigger HDR in Emby, do trigger HDR in PLEX, no matter what dimensions they are. Thanks. 1
Guest asrequested Posted December 31, 2018 Posted December 31, 2018 (edited) You change the display height not the video. I'll post a screenshot in a little while. Edited December 31, 2018 by Doofus 2
