FrostByte 5454 Posted August 3, 2019 Posted August 3, 2019 Does your TV have some kind of indicator saying it's HDR? On my Samsung I can see "HDR" on one of the screens when it triggers HDR. Otherwise my Samsung can try to simulate HDR which changes the color also, though not as good as the actual HDR.
solidus28 12 Posted August 3, 2019 Posted August 3, 2019 Hey vader, then what am I seeing on my set up? Cropped movies are clearly tripping HDR, not only can I see the brightness change but can pull the info and see that it is in HDR10 mode. Am I confusing two different modes ? If you go to MediaInfo, what's the resolution on some of your cropped movies? Maybe some resolutions now trigger, while some still don't?
Snapper 20 Posted August 3, 2019 Posted August 3, 2019 Yeah, I am curious what your crops look like. I have several HDR movies cropped to 3840x1600, and they all play in SDR which can be verified by the "Info" screen on my projector. If I set the color matching option to auto, they also play in bt.709 instead of bt.2020.
vdatanet 1619 Posted August 3, 2019 Posted August 3, 2019 (edited) If you go to MediaInfo, what's the resolution on some of your cropped movies? Maybe some resolutions now trigger, while some still don't? This one doesn't trigger HDR in Emby + Nvidia Shield. - Emby + Nvidia Shield: Doesn't trigger HDR - Plex + Nvidia Shield: Triggers HDR - Plex + Apple TV: Triggers HDR - Infuse + Apple TV: Triggers HDR Here's is a sample: http://www.vdata.net/sample.zip example.txt Edited August 3, 2019 by vdatanet
strupie 0 Posted August 3, 2019 Posted August 3, 2019 (edited) I can confirm Vaders findings. Tester, you should definitely check your vids with mediainfo. All the files that are NOT in 4K native resolution (3840 x 2160) will NOT use the HDR10 metadata. However, when I play cropped movies, my LG C9 does show the HDR logo but no HDR10 metadata is actually being processed. And this is the case for everyone here that uses Emby on Shield, I haven't seen any exceptions but you so far and I doubt very strongly that your system is processing HDR10 metadata like you're claiming. What setup are you running this on? Edited August 3, 2019 by strupie
ebr 16338 Posted August 3, 2019 Posted August 3, 2019 https://emby.media/community/index.php?/topic/64038-emby-for-android-shield-tv-not-playing-back-hdr-on-all-titles/?p=771592
