wyldemusick 2 Posted August 31, 2018 Posted August 31, 2018 The two most recent logs. EmbyServerLog 3-59pm.txt EmbyServerLog.txt
ebr 16310 Posted August 31, 2018 Posted August 31, 2018 Add me to the list of disgruntled users with the web app doing bugger all any more, and nothing showing up on the Roku now. This is from the most recent library scan fail: Cannot access a disposed object. Object name: 'SqliteItemRepository has been disposed and cannot be accessed.'. at Emby.Server.Implementations.Data.BaseSqliteRepository.CheckDisposed() at Emby.Server.Implementations.Data.SqliteItemRepository.GetItemList(InternalItemsQuery query) at MediaBrowser.Controller.Entities.AggregateFolder.LoadChildren() at Emby.Server.Implementations.IO.LibraryMonitor.Start() at Emby.Server.Implementations.Library.LibraryManager.ValidateMediaLibraryInternal(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Hi. This is not actually a problem. The server was simply re-starting at that time. What, exactly, was the problem you were encountering?
Luke 42212 Posted August 31, 2018 Posted August 31, 2018 Yea it looks to me like you restarted the server in the middle of trying to use it. Can you describe the issue in more detail? We're happy to help. Thanks.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 I need to do a session with this and start listing all the issues I run into. At this rate I'm just going to cancel the Premiere sub and scrape the thing off the computer.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 As it is, I just tried installing the beta...that got me exactly nowhere. Literally would not open the web app, restart, or exit, and had to be manually shut down through task manager before being removed and rolling back to the current release.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 In Chrome, I click on a library...nothing happens. I have to force a page reload to get anywhere...sometimes several times.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 This, by the way, is what causes me to frequently restart this thing: I can usually get the web app to respond for a bit after four, five restarts.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 Just now: waiting for the last two minutes for a page reload to move me to ONE library.I'm not even getting Emby's spinner.Still waiting.Still waiting.Still waiting.
Happy2Play 9802 Posted September 1, 2018 Posted September 1, 2018 (edited) As it is, I just tried installing the beta...that got me exactly nowhere. Literally would not open the web app, restart, or exit, and had to be manually shut down through task manager before being removed and rolling back to the current release. In Chrome, I click on a library...nothing happens. I have to force a page reload to get anywhere...sometimes several times. Is the server performing a library scan? Has a library scan finished? Edited September 1, 2018 by Happy2Play
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 Went away, made tea. Stillllll waiiiiiitttttttiiiiiiiiiiinnnnnnnnnnnngggggggggggggggggggggggggggggggggggggggg.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 Is the server performing a library scan? Has a library scan finished? No, and no. I'd go grab a log but the web app is still stuck exactly where it was.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 Oh, look, the fifth reload...gets me an empty page and a spinny.
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 Let's go to the dashboard!...let's waiiiiiiittttttttttttttttt.
Happy2Play 9802 Posted September 1, 2018 Posted September 1, 2018 Don't need web app to get log file. Path dependent on OS. \Emby-Server\programdata\logs
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 A bunch of refreshes got me to the dashboard, so, here, have another log. Maybe you can figure out what the hell I'm doing wrong here. As far as I can tell, the one thing I'm doing wrong is not scraping Emby off the system and canceling my sub. EmbyServerLog.txt
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 It's actually easier for me to go through the dashboard. Unlike Plex log, which I can go to in my sleep at this point.
Happy2Play 9802 Posted September 1, 2018 Posted September 1, 2018 What browser are you using on Windows 7?
wyldemusick 2 Posted September 1, 2018 Posted September 1, 2018 (edited) Chrome Version 68.0.3440.106 (Official Build) (64-bit) Emby 3.5.2.0 right now. I had bad luck with the beta. Edited September 1, 2018 by wyldemusick
ebr 16310 Posted September 1, 2018 Posted September 1, 2018 If you installed the beta and let it run, your database may be in a bad state because the new beta has a lot of structural changes that the current release will not understand. So, it may be best for you to start fresh and be sure an initial library scan finishes.
