awswallace 2 Posted June 28, 2018 Posted June 28, 2018 Vídeos em MP4 ou MKV, o processo de transcodificação da efeitos negativos para o processador do servidor. Um vídeo transcodificando consome 25% da CPU.
awswallace 2 Posted June 28, 2018 Author Posted June 28, 2018 Gostaria de saber de como converte o vídeo para não precisar transcodificar. Enviado de meu Moto Z2 Play usando o Tapatalk
Luke 42184 Posted July 7, 2018 Posted July 7, 2018 @@awswallace Oi, você fez o check out do recurso Converter mídia? Você pode ler sobre isso no anúncio do blog da última versão: https://emby.media/community/index.php?/blog/1/entry-423-emby-server-34-released/ Por favor, deixe-nos saber se isso ajuda. Obrigado !
fablinuxer 1 Posted October 4, 2018 Posted October 4, 2018 (edited) @@awswallace Oi, você fez o check out do recurso Converter mídia? Você pode ler sobre isso no anúncio do blog da última versão: https://emby.media/community/index.php?/blog/1/entry-423-emby-server-34-released/ Por favor, deixe-nos saber se isso ajuda. Obrigado ! Tooooooooooopppppppppp! Edited October 4, 2018 by fablinuxer
fablinuxer 1 Posted October 4, 2018 Posted October 4, 2018 (edited) Guys, how can I not transcode live tv? Congratulations to me now I'm premiere hehehehe kkkkkkkkk. Edited October 4, 2018 by fablinuxer
fablinuxer 1 Posted October 4, 2018 Posted October 4, 2018 hi Lukeany one ...... android app, browsers, always transcodes
ebr 16307 Posted October 4, 2018 Posted October 4, 2018 There could be any number of reasons for this. Please start here: Transcoding and if you still have questions follow instructions here: How to Report a Problem Thanks.
Luke 42184 Posted October 4, 2018 Posted October 4, 2018 Web browsers do not support the mpeg2 video codec. Does this answer your question?
fablinuxer 1 Posted October 4, 2018 Posted October 4, 2018 (edited) huummm I understand Edited October 4, 2018 by fablinuxer
Luke 42184 Posted October 5, 2018 Posted October 5, 2018 We're happy to give you an explanation for android if you can provide the information requested in how to report a media playback issue. thanks !
awswallace 2 Posted July 10, 2024 Author Posted July 10, 2024 (edited) When converting the media file, the status that appears is this, ready to transfer, does the file go to a folder? I selected automatic replacement, and converted it to the format, mp4-h264-acc. However, when I open it on the web, it uses video transcoding Could you suggest some format for the media to be reproduced without transcoding? Edited July 10, 2024 by awswallace
Luke 42184 Posted July 10, 2024 Posted July 10, 2024 Quote However, when I open it on the web, it uses video transcoding Hi, what did the stats feature show as the reason for transcoding?
awswallace 2 Posted July 11, 2024 Author Posted July 11, 2024 4 horas atrás, Lucas disse: Você pode anexar o log ffmpeg? Obrigado. --- As razões para a transcodificação são: O vídeo original está no codec HEVC (H.265), que não é suportado. Eu usei a ferramenta Emby para converter o vídeo para MP4-H.264-ACC e substituir o original, mas parece que o arquivo de mídia permanece no mesmo formato. Alguma sugestão? Obrigado! --- ffmpeg-transcode-948517f6-18fd-4d43-acb0-4d110a07e487_1.txt
awswallace 2 Posted July 11, 2024 Author Posted July 11, 2024 Aqui está o log de conversão usando a ferramenta de conversão emby ffmpeg-transcode-54dc2c34-aef1-496e-ad79-6976e34619e7_1.txt
awswallace 2 Posted July 11, 2024 Author Posted July 11, 2024 @Luke "Ready to Transfer" status for converted media. This indicates that the conversions have been performed but have not yet been moved to the specified final destination. My question is how to move it after being converted, because the status shows that it hasn't been moved yet.
awswallace 2 Posted July 11, 2024 Author Posted July 11, 2024 I was able to find the error, in my case the folder where the media was added, emby did not have permission, I gave permission and the transfer was carried out with the converted file. 2
