mata7 45 Posted June 27, 2018 Posted June 27, 2018 Why is a limit of 40Mbps only on the apple tv, all my 4k rips are much more then that thanks
Luke 42242 Posted June 27, 2018 Posted June 27, 2018 Hi, why do you feel there is a limit of 40 mbps? can you explain? thanks !
mata7 45 Posted June 27, 2018 Author Posted June 27, 2018 (edited) i dont know what do you want me to tell you, because there is a 40 mbps limit that we dont need it this days, apletv can handle full 4k rips mbps so why is the need to cap at 40, i dont know what to tell you Edited June 27, 2018 by mata7
Spaceboy 2573 Posted June 27, 2018 Posted June 27, 2018 Luke isn’t very good at speaking to actual humans. What he means is: You are wrong, in his opinion there is no limit on bit rate. Can you explain what error or message is making you think it’s limited 2
adrianwi 279 Posted June 27, 2018 Posted June 27, 2018 Not sure about the Apple TV 4K, but the previous aTV4 (1080p) only has a 10/100 Network Adapter, although that wouldn't explain a perceived 40 mbps limit. That said, I can't remember the last time I saw any buffering on my aTV4.
corey 317 Posted June 27, 2018 Posted June 27, 2018 Not sure about the Apple TV 4K, but the previous aTV4 (1080p) only has a 10/100 Network Adapter, although that wouldn't explain a perceived 40 mbps limit. That said, I can't remember the last time I saw any buffering on my aTV4. The Apple TV 4K has a gigabit ethernet adapter.
corey 317 Posted June 27, 2018 Posted June 27, 2018 Why is a limit of 40Mbps only on the apple tv, all my 4k rips are much more then that thanks @@mata7 -- The Apple TV app does not have a 40Mbps limit. By default the setting is set to Auto and the application does an automatic bit-rate check to determine what it can support under the current network conditions. With that said if you want to change it to something other than Auto the highest value is 40Mbps. Does that help clarify how the application works? If not, please let me know.
mata7 45 Posted June 27, 2018 Author Posted June 27, 2018 i dont know guys, like i say all my 4k rip have more than 40mbps, i this point i just dont see the point of having a 40mbps cap anymore, anyways thanks for the help
corey 317 Posted June 28, 2018 Posted June 28, 2018 @@mata7 — Like I said the app isn’t capped at 40Mbps. Are you specifically looking to NOT use the Auto option and want something higher than 40Mbps?
mata7 45 Posted June 28, 2018 Author Posted June 28, 2018 so you say that if i play a 60 or 70mbps file, the server wont transcode it because of excessive bitrate, and yes if i could select 100mbps manual like i can with oders apps that would be great
corey 317 Posted June 28, 2018 Posted June 28, 2018 so you say that if i play a 60 or 70mbps file, the server wont transcode it because of excessive bitrate, and yes if i could select 100mbps manual like i can with oders apps that would be great It shouldn’t if the setting is at Auto. If it is transcoding can you provide the server and ffmpeg logs please?
mata7 45 Posted June 28, 2018 Author Posted June 28, 2018 there is no point now because emby wont direct play full rip mkv hevc on the appletv 4k, i was just curios why the 40 mbps limit, again thanks for you help
corey 317 Posted June 28, 2018 Posted June 28, 2018 The native Apple player doesn't support MKV containers. Is it direct streaming or transcoding?
mata7 45 Posted June 28, 2018 Author Posted June 28, 2018 never mind now man, i believe im getting you confuse with my bad English
RanmaCanada 502 Posted July 28, 2018 Posted July 28, 2018 If you're using 4k pirated rips, you should be using something OTHER than an Apple TV to play them as an Apple TV will not natively play the streams properly. I'd suggest a Shield or something else. Apple TV is a horrible 4k device and anyone who buys it for that should be taken out back and shot. Sorry, that's the truth.
corey 317 Posted July 28, 2018 Posted July 28, 2018 We’re working on a custom player so 4K support should hopefully improve over the limited formats that Apple supports in their native player.
mata7 45 Posted July 28, 2018 Author Posted July 28, 2018 If you're using 4k pirated rips, you should be using something OTHER than an Apple TV to play them as an Apple TV will not natively play the streams properly. I'd suggest a Shield or something else. Apple TV is a horrible 4k device and anyone who buys it for that should be taken out back and shot. Sorry, that's the truth. first is no pirated rips, 2 apple tv play Full 4K Rips just fine with MrMC and infuse player, in my opinion apple tv 4k is a great box
