tuvx 15 Posted June 28, 2018 Author Posted June 28, 2018 Thank you for trying. With the new release, will it be addressing the mouse cursor showing (I read that issue in the forum)? Also, it maybe a training issue, but I noticed no way to navigating drop down boxes using the keyboard (i.e. click on subtitles, but cannot move to the next item in the list using arrow keys); this defeats the purpose of theater mode if we need a mouse (not just a remote).
Luke 42243 Posted June 28, 2018 Posted June 28, 2018 I haven't seen any issues with the cursor and the store app. Please make sure to describe your issue in more detail. Thanks.
Tremas 205 Posted June 29, 2018 Posted June 29, 2018 I can also report that I have seen this happen in Emby Theater for PC (not the store app). I use playlists for music videos and sometimes when using the same procedure as Post #6 I will see the overlay. To correct, I basically back out and re-shuffle and it goes away. I haven't tested it enough to reproduce it but I can do so this weekend (send logs, PC configuration, etc). I also have the issue of the cursor being on screen, but I just move it off and it doesn't return. Perhaps it is a video card/driver related issue? I'm using an AMD card if that is helpful. Could it also be related to the number of items in the playlist? I mostly have playlists which are over 200 items that are shuffled. Lastly, I believe some of my videos are of different types (avi, mp4) and different audio formats which may be a contributing factor. Different but possibly related, I also have an issue where after skipping a video (procedure in Post #6) the next video will play for about 60 seconds and then jump back to the video that was skipped. Again - I will do some testing and report back.
tuvx 15 Posted July 2, 2018 Author Posted July 2, 2018 I didn't realize there was a desktop player (not from the app store). I installed and it works fine.
Guest asrequested Posted July 2, 2018 Posted July 2, 2018 I didn't realize there was a desktop player (not from the app store). I installed and it works fine. And it is a much more capable player.
Tremas 205 Posted July 2, 2018 Posted July 2, 2018 I did some testing over the weekend and was not able to re-produce the overlay issue on either Emby Theater (PC) or Xbox. I had definitely seen it in the past few weeks, but couldn't deliberately make it happen this weekend. Same goes for the mouse being visible during playback. I will keep an eye out if it happens again, but nothing so far. Hopefully it's no longer an issue. I am able to reproduce the "skipping video" issue, but will start another thread for that.
