Mohagames205 0 Posted June 25, 2018 Posted June 25, 2018 Hey guys Today I was trying to get DLNA working on my PS3 that I connected with my Philips TV. All the videos are displying, but on some videos/movies when the subtitles work there is no sound. But if there is sound there are no subtitles. But I want both on all videos/movies. How can I fix this? I tries to make a profile in the DLNA section but that didn't help either. There were multipe logg files, I am just going to pick the latest: ----------------------- LOG: 2018-06-25 22:22:44.126Application version: 3.4.1.0http://192.168.1.9:8096/videos/e02e6b10040fc87c9884d3b210a349c7/stream.ts?DeviceProfileId=45634d41a61fff418722b16529aa5da1&DeviceId=test&MediaSourceId=e02e6b10040fc87c9884d3b210a349c7&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=1&SubtitleStreamIndex=3&VideoBitrate=15360000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&SubtitleMethod=Encode&RequireAvc=false&Tag=b55c3df07d296dfda5f070f127d4c9bd&h264-level=41&ac3-audiochannels=6&TranscodeReasons=SubtitleCodecNotSupported&dlnaheaders=true{"Protocol":"File","Id":"e02e6b10040fc87c9884d3b210a349c7","Path":"C:\\Users\\Carrefour\\Desktop\\Emby Bestanden\\films\\Bolt.2008.720p.BrRip.x264.YIFY.mkv","Type":"Default","Container":"mkv,webm","Name":"Bolt.2008.720p.BrRip.x264.YIFY","IsRemote":false,"ETag":"b55c3df07d296dfda5f070f127d4c9bd","RunTimeTicks":57819738112,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","Title":"Bolt - YIFY","VideoRange":"SDR","DisplayTitle":"720P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":653613,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":31,"IsAnamorphic":false},{"Codec":"aac","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Bolt - YIFY","DisplayTitle":"AAC stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Bolt - YIFY","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0,"IsAnamorphic":false},{"Codec":"srt","Language":"dut","DisplayTitle":"Dut","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"C:\\Users\\Carrefour\\Desktop\\Emby Bestanden\\films\\Bolt.2008.720p.BrRip.x264.YIFY.dut.srt","IsAnamorphic":true}],"Formats":[],"Bitrate":653613,"RequiredHttpHeaders":{}}C:\Users\Carrefour\AppData\Roaming\Emby-Server\system\ffmpeg.exe -ss 00:00:42.959 -f matroska,webm -i file:"C:\Users\Carrefour\Desktop\Emby Bestanden\films\Bolt.2008.720p.BrRip.x264.YIFY.mkv" -map 0:0 -map 0:1 -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -copyts -vf "scale=trunc(min(max(iw\,ih*dar)\,min(1920\,1080*dar))/2)*2:trunc(min(max(iw/dar\,ih)\,min(1920/dar\,1080))/2)*2,subtitles=filename='C\:/Users/Carrefour/Desktop/Emby Bestanden/films/Bolt.2008.720p.BrRip.x264.YIFY.dut.srt':charenc=windows-1252:force_style='FontName=Droid Sans Fallback':fontsdir='C\:/Users/Carrefour/AppData/Roaming/Emby-Server/programdata/fonts',setpts=PTS -43/TB" -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 1634032 -bufsize 3268064 -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -y "C:\Users\Carrefour\AppData\Roaming\Emby-Server\programdata\transcoding-temp\a5bb5323a217a8c435c1924486084b8f.ts"ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developers built with gcc 7.3.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libmfx --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100Input #0, matroska,webm, from 'file:C:\Users\Carrefour\Desktop\Emby Bestanden\films\Bolt.2008.720p.BrRip.x264.YIFY.mkv': Metadata: title : Bolt - YIFY encoder : libebml v1.2.0 + libmatroska v1.1.0 creation_time : 2011-04-06T07:45:53.000000Z Duration: 01:36:21.97, start: 0.000000, bitrate: 653 kb/s Stream #0:0: Video: h264 (High), yuv420p(progressive), 1280x720 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: title : Bolt - YIFY Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default) Metadata: title : Bolt - YIFY Stream #0:2(eng): Subtitle: subrip Metadata: title : Bolt - YIFYStream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for help[Parsed_subtitles_1 @ 000001e063a53920] Shaper: FriBidi 0.19.7 (SIMPLE)[Parsed_subtitles_1 @ 000001e063a53920] Loading font file 'C:/Users/Carrefour/AppData/Roaming/Emby-Server/programdata/fonts/DroidSansFallback.ttf'[Parsed_subtitles_1 @ 000001e063a53920] Using font provider directwrite[libx264 @ 000001e063e09640] using SAR=1/1[libx264 @ 000001e063e09640] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2[libx264 @ 000001e063e09640] profile Main, level 4.1Output #0, mpegts, to 'C:\Users\Carrefour\AppData\Roaming\Emby-Server\programdata\transcoding-temp\a5bb5323a217a8c435c1924486084b8f.ts': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1280x720 [sAR 1:1 DAR 16:9], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.107.100 libx264 Side data: cpb: bitrate max/min/avg: 1634000/0/0 buffer size: 3268000 vbv_delay: -1 Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default)Past duration 0.959053 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largeframe= 22 fps=0.0 q=24.0 size= 77kB time=00:00:44.24 bitrate= 14.2kbits/s speed=83.5x Past duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largeframe= 61 fps= 59 q=25.0 size= 512kB time=00:00:45.82 bitrate= 91.5kbits/s speed=44.3x Past duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largeframe= 80 fps= 41 q=25.0 size= 512kB time=00:00:46.59 bitrate= 90.0kbits/s speed=23.8x Past duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largeframe= 107 fps= 41 q=26.0 size= 768kB time=00:00:47.74 bitrate= 131.8kbits/s speed=18.2x Past duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largeframe= 134 fps= 38 q=21.0 size= 1024kB time=00:00:48.76 bitrate= 172.0kbits/s speed=13.7x Past duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largeframe= 162 fps= 32 q=18.0 size= 1024kB time=00:00:50.13 bitrate= 167.3kbits/s speed= 10x Past duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largeframe= 189 fps= 31 q=17.0 size= 1024kB time=00:00:51.15 bitrate= 164.0kbits/s speed=8.44x Past duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largeframe= 215 fps= 30 q=19.0 size= 1024kB time=00:00:52.13 bitrate= 160.9kbits/s speed=7.37x Past duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largeframe= 243 fps= 30 q=22.0 size= 1280kB time=00:00:53.46 bitrate= 196.1kbits/s speed=6.53x Past duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largeframe= 271 fps= 28 q=21.0 size= 1280kB time=00:00:54.48 bitrate= 192.5kbits/s speed=5.63x Past duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largeframe= 298 fps= 26 q=24.0 size= 1536kB time=00:00:55.85 bitrate= 225.3kbits/s speed=4.93x Past duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largeframe= 325 fps= 25 q=22.0 size= 1792kB time=00:00:56.74 bitrate= 258.7kbits/s speed= 4.4x Past duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largeframe= 351 fps= 23 q=24.0 size= 2048kB time=00:00:57.81 bitrate= 290.2kbits/s speed=3.72x Past duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largeframe= 379 fps= 22 q=20.0 size= 2304kB time=00:00:59.13 bitrate= 319.2kbits/s speed=3.36x Past duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largeframe= 407 fps= 21 q=22.0 size= 2560kB time=00:01:00.15 bitrate= 348.6kbits/s speed=3.15x Past duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largeframe= 434 fps= 21 q=23.0 size= 2816kB time=00:01:01.52 bitrate= 374.9kbits/s speed=3.02x Past duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largeframe= 461 fps= 21 q=22.0 size= 3072kB time=00:01:02.50 bitrate= 402.6kbits/s speed=2.84x Past duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largeframe= 488 fps= 21 q=21.0 size= 3328kB time=00:01:03.53 bitrate= 429.1kbits/s speed=2.71x Past duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largeframe= 516 fps= 21 q=24.0 size= 3584kB time=00:01:04.89 bitrate= 452.4kbits/s speed=2.64x Past duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largeframe= 543 fps= 21 q=24.0 size= 3840kB time=00:01:05.91 bitrate= 477.2kbits/s speed=2.57x Past duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largeframe= 570 fps= 21 q=25.0 size= 4352kB time=00:01:06.94 bitrate= 532.6kbits/s speed=2.49x Past duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largeframe= 597 fps= 21 q=24.0 size= 4352kB time=00:01:08.18 bitrate= 522.9kbits/s speed=2.42x Past duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largeframe= 624 fps= 21 q=27.0 size= 4864kB time=00:01:09.24 bitrate= 575.4kbits/s speed= 2.3x Past duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largeframe= 652 fps= 21 q=27.0 size= 5120kB time=00:01:10.57 bitrate= 594.3kbits/s speed=2.25x Past duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largeframe= 679 fps= 21 q=28.0 size= 5376kB time=00:01:11.46 bitrate= 616.2kbits/s speed=2.19x Past duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largeframe= 706 fps= 21 q=21.0 size= 5376kB time=00:01:12.83 bitrate= 604.7kbits/s speed=2.13x Past duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largeframe= 734 fps= 21 q=22.0 size= 5632kB time=00:01:13.85 bitrate= 624.7kbits/s speed=2.09x Past duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largeframe= 761 fps= 21 q=22.0 size= 5888kB time=00:01:14.88 bitrate= 644.2kbits/s speed=2.06x Past duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largeframe= 788 fps= 21 q=23.0 size= 6144kB time=00:01:16.16 bitrate= 660.9kbits/s speed=2.02x Past duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largeframe= 815 fps= 21 q=20.0 size= 6144kB time=00:01:17.18 bitrate= 652.1kbits/s speed=1.97x Past duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largeframe= 841 fps= 21 q=19.0 size= 6400kB time=00:01:18.25 bitrate= 670.0kbits/s speed=1.93x Past duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largeframe= 870 fps= 21 q=21.0 size= 6656kB time=00:01:19.57 bitrate= 685.2kbits/s speed= 1.9x Past duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largeframe= 897 fps= 21 q=19.0 size= 6656kB time=00:01:20.59 bitrate= 676.5kbits/s speed=1.85x Past duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largeframe= 924 fps= 21 q=22.0 size= 6912kB time=00:01:21.92 bitrate= 691.2kbits/s speed=1.82x Past duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largeframe= 951 fps= 20 q=19.0 size= 7168kB time=00:01:22.94 bitrate= 708.0kbits/s speed=1.78x Past duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largeframe= 979 fps= 20 q=23.0 size= 7424kB time=00:01:23.96 bitrate= 724.3kbits/s speed=1.74x Past duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largeframe= 1006 fps= 20 q=24.0 size= 7680kB time=00:01:25.33 bitrate= 737.3kbits/s speed=1.71x Past duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largeframe= 1032 fps= 20 q=21.0 size= 7936kB time=00:01:26.27 bitrate= 753.6kbits/s speed=1.68x Past duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largeframe= 1060 fps= 20 q=21.0 size= 8192kB time=00:01:27.59 bitrate= 766.1kbits/s speed=1.66x Past duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too largePast duration 0.958031 too largePast duration 0.975029 too largePast duration 0.968010 too largePast duration 0.961021 too largePast duration 0.978020 too largePast duration 0.971031 too largePast duration 0.964043 too largePast duration 0.981010 too largePast duration 0.974022 too largePast duration 0.967033 too largePast duration 0.960045 too largePast duration 0.977013 too largePast duration 0.970024 too largePast duration 0.963036 too largePast duration 0.980003 too largePast duration 0.973015 too largePast duration 0.966026 too largePast duration 0.959038 too largePast duration 0.976006 too largePast duration 0.969017 too largePast duration 0.962029 too largePast duration 0.979027 too largePast duration 0.972008 too largePast duration 0.965019 too large
Luke 42238 Posted June 27, 2018 Posted June 27, 2018 That's strange. It's stream copying 2 channel aac stereo audio and you're saying you get no sound with that? I would have thought it would support that.
Mohagames205 0 Posted June 27, 2018 Author Posted June 27, 2018 That's strange. It's stream copying 2 channel aac stereo audio and you're saying you get no sound with that? I would have thought it would support that. Idk, I got it to work on my PS4 wuth Audio and Subtitles by changing the SRT subtitle profile from Embed Within Container to External download. I also tried this on my PS3 but it didn't work. On mp ps3 it says "No audio tracks available" or if there is audo it says "No subtitles aivailable". It's very frustrating
Luke 42238 Posted June 28, 2018 Posted June 28, 2018 Does the ps3 not support the embedded srt? i guess that is the question. of course we could also burn them in with server transcoding.
