laifisnau 0 Posted June 25, 2018 Posted June 25, 2018 Hello. First of all, I apologize for my English (I'm Italian). I write here because I have a problem with transcoding. I have a system based on APU AMD Ryzen 2400G (VEGA 11 video card, lastest driver), windows 10 pro 64bit (with lastest update), 16GB ram, etc. With none of my files (all HEVC) I can make transcoding work. The encoding in h264 works (in the task manager I see that the video card is engaged at about 20%, the encoding section is 50% engaged) while the decoding is not (the decoding section remains at 0% while the cpu with video in 4k goes to 70 %). I have already changed ffmpeg by putting a version with enabled -amf. The same videos are easily decoded by video card watching them with vlc, mediaplayer, etc. I enclose the two logs. The file in 4k is a 10bit HVEC from around 50Mbps, 1080p is a simple 8bit and 8Mbits HEVC movie. Thanks for your help. 4k.txt 1080p.txt
Luke 42212 Posted June 25, 2018 Posted June 25, 2018 Hi there, please attach complete ffmpeg logs, thanks.
Luke 42212 Posted June 25, 2018 Posted June 25, 2018 Yea I don't think there is decoding with amf, right? I think we need to use dxva2.
laifisnau 0 Posted June 25, 2018 Author Posted June 25, 2018 (edited) Yes the decoding does not work (only the encoding in h264 works). But with VLC, Windows Media Player etc. hardware decoding seems to work (I see the decoding graphics section in the task manager at 50-60%). How should I do to enable DXVA2 in emby? Edited June 25, 2018 by laifisnau
Luke 42212 Posted June 25, 2018 Posted June 25, 2018 You can't at this point. We're looking into it for the next release, thanks.
laifisnau 0 Posted July 17, 2018 Author Posted July 17, 2018 Hello. I have updated the server to version 3.5.0.0. Dxva2 does not work yet Stream mapping: Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_amf)) Stream #0:1 -> #0:1 (dts (dca) -> mp3 (libmp3lame)) Press [q] to stop, [?] for help [h264_amf @ 00000223ab278980] encoder->Init() failed with error 1 Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height [libmp3lame @ 00000223ab1e66c0] 3 frames left in the queue on closing Conversion failed! ffmpeg version 4.0.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7.3.1 (GCC) 20180710 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100
laifisnau 0 Posted July 17, 2018 Author Posted July 17, 2018 (edited) Done 4k.txt Edited July 17, 2018 by laifisnau
Luke 42212 Posted July 17, 2018 Posted July 17, 2018 As you can see, dxva2 was used for decoding but there was possibly an encoding failure. Make sure that windows is up to date and that your graphics drivers are up to date. Then if there's still an issue you could try turning off gpu encoding but leave decoding on.
laifisnau 0 Posted July 17, 2018 Author Posted July 17, 2018 I ran windows update just before, the video card drivers are updated to the latest version. Yes I have seen, but it always works as before (3.4.x.x), I was doing the decoding correctly but not the encoding. But first the transcoded videos were enjoyable, but now they go to about 18fps
laifisnau 0 Posted July 17, 2018 Author Posted July 17, 2018 (edited) I turned off gpu encoding but same problem, transcoded video at 18fps 4k gpu enc off.txt Edited July 17, 2018 by laifisnau
Luke 42212 Posted July 17, 2018 Posted July 17, 2018 Well there's no failure anymore, so it is working.
laifisnau 0 Posted July 17, 2018 Author Posted July 17, 2018 It is not working well. With all the other software (vlc, wmp, plex with the monthly pass) the videos are played smoothly. Not with emby.
