arrbee99 1836 Posted January 5, 2020 Author Posted January 5, 2020 Also needs moving down ? Would be nice if the downwards shift could be a different value from Movies, etc. But still, thanks again, like things much better now. Thanks very much.
arrbee99 1836 Posted January 5, 2020 Author Posted January 5, 2020 Any chance if you're really bored tomorrow having a look at these which used to work - Had a nice gradient on Movies or Series from top to bottom of whole page - /*Add gradient to main movie or episode page*/ /*.detailPageContent { background: linear-gradient(rgba(0,0,0,0),rgba(0,0,0,.9)); }*/ and each episode in the list was in a darker grey elongated rectangle to make it easier to read - /*Add transparent grey background to episode summary*/ #childrenContent div.listItem-content {background: rgba(0, 0, 0, 0.3);}
Happy2Play 9811 Posted January 5, 2020 Posted January 5, 2020 Any chance if you're really bored tomorrow having a look at these which used to work - Had a nice gradient on Movies or Series from top to bottom of whole page - /*Add gradient to main movie or episode page*/ /*.detailPageContent { background: linear-gradient(rgba(0,0,0,0),rgba(0,0,0,.9)); }*/ and each episode in the list was in a darker grey elongated rectangle to make it easier to read - /*Add transparent grey background to episode summary*/ #childrenContent div.listItem-content {background: rgba(0, 0, 0, 0.3);} Gradient affects all itemdetails pages. But it would appear it did that before. /*Add gradient to main movie or episode page*/ div.itemMainScrollSlider { background: linear-gradient(rgba(0,0,0,0),rgba(0,0,0,.9)); } /*Add transparent grey background to episode summary*/ div.listItem-withContentWrapper div.listItem-content {background: rgba(0, 0, 0, 0.3);} Change to make Album shift down also. div.topDetailsMain {padding-top: 30em; } to div.topDetailsContainer {padding-top: 30em; } Also needs moving down ? Would be nice if the downwards shift could be a different value from Movies, etc. But still, thanks again, like things much better now. Thanks very much. Don't see a way to make different for each type as the details page is the same for all. Only difference I currently see is all items are this div.topDetailsContainer.flex.flex-direction-row-reverse and Albums are div.topDetailsContainer.flex.flex-direction-row So you can target those two separately with that, instead of "div.topDetailsContainer"
arrbee99 1836 Posted January 6, 2020 Author Posted January 6, 2020 Thanks very much. seems all that works great. These seem to work separately for Movies and Albums - /*New move stuff down Movies Series */ div.topDetailsContainer.flex.flex-direction-row-reverse {padding-top: 41em; } /*New move stuff down Albums*/ div.topDetailsContainer.flex.flex-direction-row {padding-top: 41em; } just need to fine tune the em values. Haven't spotted any unintended consequences, touch wood. 1
Happy2Play 9811 Posted January 6, 2020 Posted January 6, 2020 Thanks very much. seems all that works great. These seem to work separately for Movies and Albums - /*New move stuff down Movies Series */ div.topDetailsContainer.flex.flex-direction-row-reverse {padding-top: 41em; } /*New move stuff down Albums*/ div.topDetailsContainer.flex.flex-direction-row {padding-top: 41em; } just need to fine tune the em values. Haven't spotted any unintended consequences, touch wood. "div.topDetailsContainer" would cover both unless you what them different. 1
arrbee99 1836 Posted January 6, 2020 Author Posted January 6, 2020 Thanks. Will keep them separate for now
seanbuff 1356 Posted January 6, 2020 Posted January 6, 2020 I feel like a variation of this was just implemented by default in the latest server beta (4.4.0.6) Big empty space at the top with item details all moved further down - intentional or not?
arrbee99 1836 Posted January 6, 2020 Author Posted January 6, 2020 If its intentional I wouldn't complain, though others, not so sure. Guess I'll have to remove stuff too see what it looks like... Hope I'm not going to be pestering Happy2play again.
arrbee99 1836 Posted January 6, 2020 Author Posted January 6, 2020 (edited) Looks quite decent to me, though I can't actually remember what it was like before very well. Like you say, moved stuff down a bit and can see more / brighter version of the backdrop, like Android TV version I think ? Would prefer less graduation though. Edit - and not applied to Collections yet it appears. Edited January 6, 2020 by arrbee99
Happy2Play 9811 Posted January 7, 2020 Posted January 7, 2020 I feel like a variation of this was just implemented by default in the latest server beta (4.4.0.6) Big empty space at the top with item details all moved further down - intentional or not? Would need a example but I do not see anything new in .6 besides reduced poster size.
arrbee99 1836 Posted January 7, 2020 Author Posted January 7, 2020 Would need a example but I do not see anything new in .6 besides reduced poster size. Think backdrop is brighter and more graduated.
Happy2Play 9811 Posted January 7, 2020 Posted January 7, 2020 (edited) Okay the machine I am currently looking at has display scaling so everything looked normal. Changing it back to 100% is see changes. Need to look at a unmodified system. Edited January 7, 2020 by Happy2Play
seanbuff 1356 Posted January 7, 2020 Posted January 7, 2020 Yeah you'll only see the changes when the window is almost at max size
PenkethBoy 2068 Posted January 7, 2020 Posted January 7, 2020 seeing no reduction in size of the huge posters with 4406
arrbee99 1836 Posted January 24, 2020 Author Posted January 24, 2020 Would anyone know please how to get rid of the album cover here - so that the controls move up level with the Best of Bowie bit (and then I can move everything down a bit more). Thought it might be something to do with - div.detailImage detailImage-side {display: None !important; } but it doesn't work and its not like I have any idea what I'm doing...
Happy2Play 9811 Posted January 24, 2020 Posted January 24, 2020 Would anyone know please how to get rid of the album cover here - so that the controls move up level with the Best of Bowie bit (and then I can move everything down a bit more). Thought it might be something to do with - div.detailImage detailImage-side {display: None !important; } but it doesn't work and its not like I have any idea what I'm doing... Remove the container instead of the image. div.item-side-imageContainer {display: none; }
Happy2Play 9811 Posted January 24, 2020 Posted January 24, 2020 (edited) Would anyone know please how to get rid of the album cover here - so that the controls move up level with the Best of Bowie bit (and then I can move everything down a bit more). Thought it might be something to do with - div.detailImage detailImage-side {display: None !important; } but it doesn't work and its not like I have any idea what I'm doing... But your code should be "img.detailImage.detailImage-side", which works also. Edited January 24, 2020 by Happy2Play
arrbee99 1836 Posted January 24, 2020 Author Posted January 24, 2020 Excellent. That'll do nicely thank you
