TheTabman 6 Posted June 24, 2018 Posted June 24, 2018 (edited) Greetings, I'm trying to play a 10bit h264 Flac mkv video file with external ASS subtitles on my (relatively new and still shiny) Vero4k with OSMC/Kodi. The Kodi add-on and Emby Server are up-to-date, and my Emby server is some old Win7 dual core intel CPU with 4GB. The files in question is "s01e0 - Chou Kousoku Galvion - 01 [720p] [ARR].mkv" and "s01e0 - Chou Kousoku Galvion - 01 [720p] [ARR].eng.ass".If I copy these two files onto the Vero4k I can directly play them, albeit in software but without any problems or stuttering. If try to play the video file with the emby add-on, it needs to be transcoded. And when my little server tries to transcode such a 720p video file, not only does the picture quality suffer majorly, but it also comes with stuttering and occasional 1-5 seconds breaks. And that makes me sad Quote from the [deleted log] file: 2018-06-24 21:36:14.633 Info HttpServer: HTTP POST http://192.168.0.103:8096/emby/Items/3a9db06cd621d91fa6137da3a656c2a0/PlaybackInfo. UserAgent: Emby-Kodi (3.0.31)2018-06-24 21:36:14.633 Info App: User policy for MediaServer_Admin. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True2018-06-24 21:36:14.633 Info App: Not eligible for DirectPlay due to unsupported subtitles2018-06-24 21:36:14.633 Info App: Not eligible for DirectStream due to unsupported subtitles2018-06-24 21:36:14.633 Info App: Profile: Kodi, Path: \\MEDIASERVER\D Film\Japan\Anime Series UNKNOWN\Super High Speed Galvion\Season 01\s01e0 - Chou Kousoku Galvion - 01 [720p] [ARR].mkv, isEligibleForDirectPlay: False, isEligibleForDirectStream: False2018-06-24 21:36:14.633 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 192.168.0.100, IsInLocalNetwork: True2018-06-24 21:36:14.633 Info App: Not eligible for DirectPlay due to unsupported subtitles2018-06-24 21:36:14.633 Info App: Not eligible for DirectStream due to unsupported subtitles2018-06-24 21:36:14.633 Info App: Profile: Kodi, Path: \\MEDIASERVER\D Film\Japan\Anime Series UNKNOWN\Super High Speed Galvion\Season 01\s01e0 - Chou Kousoku Galvion - 01 [720p] [ARR].mkv, isEligibleForDirectPlay: False, isEligibleForDirectStream: False2018-06-24 21:36:14.633 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 192.168.0.100, IsInLocalNetwork: True2018-06-24 21:36:14.633 Info App: Not eligible for DirectPlay due to unsupported subtitles2018-06-24 21:36:14.633 Info App: Not eligible for DirectStream due to unsupported subtitles2018-06-24 21:36:14.633 Info App: Profile: Kodi, Path: \\MEDIASERVER\D Film\Japan\Anime Series UNKNOWN\Super High Speed Galvion\Season 01\s01e0 - Chou Kousoku Galvion - 01 [720p] [ARR].mkv, isEligibleForDirectPlay: False, isEligibleForDirectStream: False2018-06-24 21:36:14.633 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 192.168.0.100, IsInLocalNetwork: True What can I do to make it play on my Vero4k box without copying it first onto it? Thanks in advance Edited June 27, 2018 by TheTabman
Angelblue05 4132 Posted June 24, 2018 Posted June 24, 2018 Can you provide your Kodi log capturing playback? Thank you
TheTabman 6 Posted June 24, 2018 Author Posted June 24, 2018 (edited) Here's the Kodi Log: kodi_25.06.00-43.log If you search for "Galvion" you should first find the part when the video was started (and transcoded) with the Emby add-on, around line 239. Later at line 357 I played the same files directly from /home/osmc/TV Shows/. Also just in case this is only a malformed subtitle (though I had a quick look at it and couldn't see any problems) file here's the ASS file: s01e0 - Chou Kousoku Galvion - 01 720p ARR.eng.zip And I forgot this to mention in my previous post, but this is the first time I have this problem with my new Vero4k box. All other 8bit and 10bit x264 or HEVC videos with ASS subtitles that I tried can be streamed directly from the Emby server without the need for transcoding. Hope this helps and thanks for the effort @@Angelblue05 . Edited June 24, 2018 by TheTabman
Angelblue05 4132 Posted June 24, 2018 Posted June 24, 2018 (edited) I think this is not working because of the device profile sent by the add-on. Let me see what I can do to fix this. Edited June 24, 2018 by Angelblue05
Solution Angelblue05 4132 Posted June 25, 2018 Solution Posted June 25, 2018 (edited) @@TheTabman Can you try this build? Install from zip in kodi, over your current install. Let me know if it's any better. plugin.video.emby-3.0.31a.zip Edited June 25, 2018 by Angelblue05 1
TheTabman 6 Posted June 25, 2018 Author Posted June 25, 2018 (edited) Thanks, now the Emby add-on plays the file without transcoding And what do you think, should I try to make the people over at the OSMC forum aware of this? And if so, what exactly should I tell them? Thanks again @@Angelblue05 , your work is much appreciated. Edited June 25, 2018 by TheTabman 1
Angelblue05 4132 Posted June 25, 2018 Posted June 25, 2018 Thank you, glad it is working now. I'll be posting a new build to the repository later today when I have a bit of time. 1
