Malvazar 0 Posted June 24, 2018 Posted June 24, 2018 So I've been running my server for a while now, and I only just recently got around to migrating my TV Show library over to it. Things seem to be going well, except for some reason Emby is deciding to duplicate random episodes 5 to 20 times. Not sure why its doing this. Everything in my system folders is fine with no duplicates, its just a problem with the server it seems. Any insight into this would be great. Here is a screen shot for reference.
Luke 42246 Posted June 24, 2018 Posted June 24, 2018 Hi, what are the file names of these files? Thanks.
Malvazar 0 Posted June 24, 2018 Author Posted June 24, 2018 It's only one file, and its named (Doctor Who S03E01 Smith And Jones).
Luke 42246 Posted June 24, 2018 Posted June 24, 2018 Can you use the metadata editor for each of those three to see what files they're pointing to? thanks.
Malvazar 0 Posted June 25, 2018 Author Posted June 25, 2018 I ended up deleting the entire cache folder, and the library. After re-adding the library it seems to be fixed now.
